Toroid-magnet-generator
Started by wizkycho, August 30, 2006, 06:26:18 PM
wizkycho
Many thanks for the input !
It is not said that the input should be 1000W and over to make output is overunity.
These are probably the limit power of their machine, and generator is capable
of giving overunity at say 100W input ? Am I right here ?
If I am than at lower input powers COP should be even biger than just 1.2 cause of all the losses
in input and output at 1kW power.
even COP 1.5 should be very darn good for making electrical furnace which sustains itself
wiz
Paul-R
oouthere
I've built the torroidal generator, it's not o/u.
Rich
wizkycho
Quote from: oouthere on August 31, 2006, 09:31:03 PM
Rich
hi rich !
Can we see some pictures, data etc or should I (we) just believe it ?
I am building this. already ordered machining. NdFeB magnets 32MGOe from both sides
can make core go to sattuartion (if this will do something).
Can vary distance etc.
Core is laminated silicon Iron from 100W toroid trafo. Using four separated coils at first...
wiz
oouthere
I built three different versions.  This is the second one with one coil filling the complete space between two magnets.  The third one had an additional coil that was the same width as the neo magnet.  The coil that was the same width put out about 75VAC but would not sustain any type of load.  The other coil was about useless.
Out of time, I'll try to post a picture later.
Rich
