real free energy with capacitors thru inductance
Started by jimbo, May 06, 2016, 12:10:35 PM
jimbo
Tesluh
The swinging switch is just to release the energy .I've changed that to a neon they fire at 90 volts .I now use a Variac and a car high voltage coil with a diode . with a good earth ground . I think I might have seen something the last time .I put in four new grounds and put a meter between a positive on a 12 volt battery and got a reading     didn't happen with only one.  Better I think.   I was able to fire off 5 neons over 5 caps  with the new set up didn't go to 6 got nervous ! It's random firing on each neon.star low on the Variac and adjust up.put something over the caps in case one of the neons gets loose   boom!!!  The voltage can rise above the caps self destruct level it's like a land mine. I'm trying to work out a way to get a real good set up to measure the in and out of the system .its a random pulsing not easy to do a reading .using 5 caps I have 3 totally isolated from the charging energy aka not connected yet there charging just like the rest and the one on the positive source end only discharges what's in the cap.   Unless you short it to ground .nothing is flowing Thu the system just potential. The plate on the first cap charge's to full and the rest just adjust to match electron to proton each robing from the one next to it charging the string . the higher voltage just quicken the charging .just Watch out!!! With that .
Tesluh
What is the load are you powering with this device?
what is the purpose of the neon bulb?  is it some sort of draw to cause energy to flow?
If there is any way I could figure out exactly how to duplicate the effect you are creating I could try it and add to your description.  I have 4 car battery sized capacitors (10uf @4kvdc) that would work perfect for this experiment.
Tesluh
could a safety spark gap be used somehow to prevent over-voltage in the caps?
jimbo
The neons are the spark gap.    voltages to low for open air gap. Need higher voltages use more neons in series .the neons don't let the hivoltage from the car coil get past 90volts the caps are 450  volt area. For safety .no load just the 4watt bulbs I've set A-side for now.just trying to come up with a way to measure the ins and out of the system for now .like a volt meter on each cap and an amp meter on the inverter. Might do it. ,1 neon with a 4watt blub might give you enough time to get readings from the five voltage meters and the one amp meter but a video might be better to capture in real time all the meters at once freeze frame. Time line do math decern  energy involved. Hard to deal with can only read so many meters at once !need recording. Jim out
Tesluh
Thank you,
I dont think you need extreme measuring equipment, you have a battery eventually going to ground (yes i understand this is an open system but basically you aren't connecting to mains power) so really as long as you can maintain or increase charge in the battery and power a load you have collected excess from the ambient on the remaining capacitor plates.  That would be relatively easy to display, its hard to trust meters when working with some of these devices.  Higher voltage and maybe higher frequency could only help from what I can tell.  I am tempted to try this and see what happens, just trying to study it first to make sure its safe and worthwhile.
Once you have the caps charged, what happens if you disconnect them?  how long do they take to run down?
what is the draw on the battery while it's running, minimal?
