Graham Gunderson's Energy conference presentation Most impressive and mysterious
Started by ramset, July 11, 2016, 07:00:18 PM
verpies
Quote from: k4zep on August 10, 2016, 09:37:55 AM
But with the transformer action dropping the voltage to about 12-20 VAC, what is the value then? ??? ?  The transformer is not 1/1!  Transfer is in the mw range.
I was more concerned about the Gate Leakage from the MOSFETs that are AFTER the transformer.
AFAIK these MOSFETs form the synchronous rectifier and the secondary/output 1μs interrupter circuit.
I couldn't find anything under the part number on Spokane1's diagram, C2M002510D. Neither the Cree website nor DigiKey lists anything with that part number that I could find. However, the nearest thing I could find is the C2M0025120D mosfet, 1200V 90A 34mOhm Rdson. Only 69 dollars and 80 cents _each_, from DigiKey. Data sheet attached:
verpies
2.7nF gate capacitance ...OUCH!
...but only 15pf reverse transfer capacitance (w/o transconductance multiplier).
Spokane1
Quote from: verpies on August 10, 2016, 10:11:02 AM
Dear verpies,
What kind of leakage takes place if the MOSFETS are constantly on? In order to pass energy through a parasitic Miller capacitance don't we have to have AC present? In this circuit the MOSFETS are on for 20 uS  (50 k cps) and then are briefly shut off for 5 to 1000 nS (I don't know the exact timing).  Wouldn't this very narrow duty factor have a tendency to reduce the kinds of losses you are addressing?
Spokane1
Spokane1
Quote from: TinselKoala on August 10, 2016, 10:29:33 AM
Dear TK,
Thanks for pointing  this out. I shall make corrections on the next revision.
Let me know if you can see anything else that needs improvement.
Spokane1
