Aetheric transformer/inductor
Started by aether22, July 23, 2018, 09:06:04 PM
onepower
Conrad
QuoteMY HAIR IS STICKING OUT !
How can I get rid of this phenomenon? Be careful incase you have longer hair than me !
Get rid of it?, it looks like you could use all the help you can get my friend and were in the same boat. First it was the receding hair line then reading glasses then that infernal ear hair. You know back when me and dad were kids I didn't think being older would be like this. It's not that bad and life is pretty relaxing without all the drama of youth.
And time marches on... time marches on.
MasterPlaster
I wonder if how a coil is wound does effect its characteristics. Long ago I had some thoughts but lost the thread. Still, kept a picture.
https://en.wikipedia.org/wiki/List_of_prime_knots
aether22
Quote from: MasterPlaster on August 01, 2018, 05:24:06 PM
I palmed a picture of knots like that and one similar looking to 7 (4) produced a tangible energy.
So I made the knot physically and without changing it's form I realized how it was working, that lead after some modification to the attached coil which creates a circular flow of energy through the wires despite the wire being anything but continuous, the energy is transferred twice per revolution through spiral join.   And the energy that does not move through the spiral in the CCW direction is sent both directions into the center.
But the main point is that energy can be made to move in a loop energy if the loop is not composed of one continuous loop of wire, this reminds me of the Kipper coil which did just that.
You could for instance make such a knot between the input and output between say the primary and secondary of a transformer as shown in an image I just made, will this transfer energy into a vortex centering on the transformer (or other component inside)?  Yes.  Will that result in Free Energy?  Maybe eventually.   And be eventually I mean that it can take time sometimes for this aetheric tech to grow the energy.
An important point to make about this is that even if it takes you an hour of fiddling to make a nice circle, get all the turns the same way (right handed) and  all that, the potential to do this with just knotting some lead wire up is the point I want to make, the down side is subtle differences make a huge difference in how a device works with the aether, the upside is that subtle intentional changes can make a regular device powerful at involving aetheric energies!   So as long as you understand how it works, it take little to have a huge impact, the direction some wire is wound or twisted, the way the end of a wire points, how a wire is cut.
aether22
Sensitivity testing update; simply been putting it off, will get to it. It can work well, but can easily be disrupted by various details than need to be shaken out with every change, especially change of location.
But, I wanted to share some details on why Free Energy used to be a lot easier to come buy, especially long ago...
Consider Tesla, Stubblefield and some others of that day, they were around for the carbon arc lamp.
Let's consider theis technology...
If had a spark gap which has been recognized as being connected to radiant energy, literally the arc radiates light, but more than just light.
These develop UV A, B and C, UV has been associated by this kind of energy. (glass can filter out the worst of that)
They develop a lot of light, full spectrum (and can be rather energy efficient also)
They develop a lot of iR, also connected to aetheric type energy.
They develop large amounts of radio frequency interference, so they create a lot of RF energy.
They create sound, some have claimed that when a spark gap produces the right hiss stuff happens, so sound.
They produce a lot of heat, thermal energy.
They produce Bucky balls, which have been associated with this kind of aetheric energy.
They create a plasma, and ions
They create ozone, ozone has been noted as being connected to Free Energy, especially in motor systems.  Other chemical things going on also.
Better arcs included iron pyrite, this can been connected to Ormus and antigravity (Hinthorne).
Carbon itself is an element associated with aetheric energy.
The coils can create EMF, and there can be feedback between energy from the arc being absorbed into the coils, aetheric energy that radiated from the arc and reabsorbs in the coils and goes around again and again converges with physical energy.
So just that point simple thing, an electric light, and you wonder why you can't get Free Energy with LED's!
The carbon arc lamp creates broad spectrum EM (radio to UV-C) and Thermal and magnetic EMF and ions and sound and exotic materials (bucky balls, ozone).
So guess what, if you try a Stubble-field earth battery, poorly constructed, in a poorly chosen ground, or a Tesla Magnifying transmitter or similar, guess what?!  You don't get squat!
They used wire that corroded over time, but what you don't know is that wire that corrodes over time actually records aetheric energy in it's decay!  That is (part of what) what Keshe is doing with his nanocoating, any system that changes over time records aetheric energies.  There is a Russian outfit using this fact to record energy from inside pyramids into setting of epoxy, any time a unique pattern/structure is formed in an energy field it records that energy field and this can be compounded.   This is the pyramid being welded levitating, this is old broken down telegraph lines weaving along earth energy lines becoming activated with aetheric energy.  This is commutators in things line the Newman system becoming a key part, others have claimed that similar sparking contacts can produce exotic energy coatings with weird effects.
If you want Free Energy, you need to both use aetheric energy, and also have a wide range of energies as well as intense energies, the depth (intensity) and breadth (type and freq. range) of energy you embody as well as the sheer quantity all comes into play, once you have enough combined with aetheric principles working together, then you have the necessary conditions to break the laws of physics as we know them, things can be done of which Free Energy is hardly the most stunning.
Free Energy comes about with the joining of wide band high intensity energy (possible to avoid in part with collecting high bandwidth energy from environment) with aetheric energy.   This is easy to develop, but only if you know what you need to do and how to do it.
Tynoo
Hi aether,nice work !
My congratulations for the dedication, the effort and the courage,in sharing these subjects publicly !!
I read all your posts and I understood better the other forms of energy available on our planet,but unfortunately it does not interest to exploit a lot of people,many of them readers of these forums...!!
All my professional life I dealt with electricity and electronics and never imagined that these forms of energy existed.
GO AHEAD MAN WITHOUT FEARS !
I built two QEG engines (Quantum Energy Generator)when they resonated and produced energy,I sat down speechless for what my eyes saw...
(someone interested, I show the videos)
All the best
Tynoo
