Heins' new videos and few corrections
Started by nix85, March 25, 2020, 12:08:24 PM
nix85
Quote from: lancaIV on March 28, 2020, 01:30:54 PM
You are right ! 2 possibilities  or  2 possible cases
I did only show to you the detective work by us,how we have to understand statements and numbers.
DC ?  Would have been 1866 common,battery/ jar based !
Pulsed by magnetic relay or AC   unexpected !
But 21,4 KHz to 42,8 Khz is a wide vibration ,sonic, spread  ,is it not ?
By which efficiency ? Some data in this book ?
You are nitpicking, Keely used standard meaning of pitch, so when he says 1 vibration he means 1Hz.
nix85
To correlate Keely's 7 levels of division with Theosophy, here is a table showing how ultimate atoms (not atoms in our sense, more like tiniest bubbles of ether, something akin to Planck's constant) of the first Adi plane join to produce ever bigger particles of lower planes.
These 7 planes represent the first Cosmic Plane. He doesn't give number of Cosmic Planes but according to Bentov there are 7.
From Solar System by Arthur Powell.
Âdî                  1           1
Anupâdaka       49         49
Âtmâ               49^2     2,401
Buddhi             49^3    117,649
Manas              49^4    5,764,800
Kâma               49^5    282,475,249
Sthula              49^6    13,841,287,201
nix85
You can imagine how mindblown i was when i first correlated this x49 increase of density of matter on different planes with two contactee cases which claim that speed of light increases x49 (Oscar Magocsi) and x50 (Ummo) on each plane above. This 50 to 49 discrepancy can be attributed to their "mistake", actually ratio being 49.
http://amasci.com/freenrg/h2oblast.html
About 1866 while he was pursuing a line of experimentation in sonic vibrations, he discovered a hitherto unknown energy. He was subjecting water to sonic vibrations and had an explosion which wrecked his apparatus. Six years of intensive experiments passed before he was able to produce this energy at will. He found that 42,800 vibrations per second would vaporize water instantly into energy. (11) He named this energy ETHERIC FORCE. Keely called the process of changing the substance of water into etheric force : DISSOCIATION. (6)
https://books.google.pt/books?id=CXQ8XxYKYMIC&pg=PA136&lpg=PA136&dq=keely+vibrations+per+second&source=bl&ots=w6Sbse51qT&sig=ACfU3U0xmPVreABmzMuarqtena6K90gvMw&hl=de&sa=X&ved=2ahUKEwiyoqSr373oAhXuYt8KHRQbDeEQ6AEwBHoECAoQAQ#v=onepage&q=keely%20vibrations%20per%20second&f=false
",,,,, The first etheric cord on the first octave induces 42800 vibrations per second, .... "
To disintegrade quartz is as same as dissociate water ?
Explain it to me,please,nix85 !
nix85
Quote from: lancaIV on March 28, 2020, 02:05:10 PM
I don't know, obviously he finds that frequency quite special.
Both water and crystals are considered alive.
Reminds me of Kowsky but he used radio frequencies.
