Allan's Transformer as a Generator
Started by AllanV, August 26, 2020, 12:35:03 AM
seychelles
SO ARE YOU STIPULATING THAT THERE ARE THREE TRANSFORMERS.
leonelogb
My friend Thank you, I thing that I got the whole idea now, I have the transformer as I told you. The hard part will be making the gap, anyway I'll try to do this today God willing. Thanks!
AllanV
Quote from: seychelles on September 07, 2020, 07:30:50 AM
Hi seychelles,
Understand how it works, the principle, the method to get a result can take a few directions. In a full AC configuration two transformers could be used but these would need several windings each.
A spring loaded gap could work.
You need to be an experimenter to build anything and able to work within different disciplines.
I am not in a position to build these for others just to give an indication how it works.
all the best,
Allan
AllanV
Quote from: leonelogb on September 07, 2020, 08:05:56 AM
Hi leonelogb,
I have a 11Kw transformer, as new, and was thinking that a 1mm cutting disc on the outside legs may work.
First set every thing up without a gap and then make adjustments later. In theory a gap is not required but it allows some adjustments when a capacitor is involved.
If enough energy can be summoned up to do lots of work, I would like to see if ordinary house wire would work. Leave the insulation on the individual cables and use a large core. So little is needed to get a current to flow, and the voltage should come up after a few cycles.
Another way has been seen that I will draw out, it involves two transformers only and of course the two smaller driving ones.
all the best,
Allan
leonelogb
My friend, today I tried to make the circuit, but I had not time to do it with transistors (lack of time). I must do it with AC rectified and I saw some gain but not as it should be. I am going to give you the image of the circuit that I think I should do and / or did. Also, the photos of some transformers that I am using.
Thank you very much for this last diagram that you put, it looks more interesting and easier, I will do it tomorrow if God willing. Thank you for your kindness to share your knowledge and effort with us, only that since this is public, I also worry about you. Anything this is my email leonelogb@yahoo.com.
Quote from: AllanV on September 07, 2020, 05:31:09 PM
Hi leonelogb,
all the best,
Allan
