Energy Generation by moving Mag Field through Static Steel Core & Copper Coils
Started by Ufopolitics, April 07, 2022, 09:40:19 AM
Ufopolitics
Hello to All,
Here I will share the Spec's of my Exciter Coils.
They are wound with 23 Gauge wire and the winding sequence is shown on Graphic.
This Stator came off an AC Blower Induction Motor, which I previously tested with same armature, and the results were awful, very low output...so I stripped it.
And took it off its outer Housing...
This Stator have a total of 36 Tooth, so I used groups of nine (9) slots/tooth for each coil, and two would be dedicated to Exciiter and other two to the Main Output Coils.
There is a big difference on the Stator windings of Universal Motor Stators and Generator Stators, and I am not referring to the wider (spread over time) way to  wind them, but to the direction of windings...
In a Universal Motor, windings are Both following the same direction to wind, either CW or CCW, in order to generate a North and a South facing the Rotor/Armature...
In the case of a Generator, it is the Opposite, meaning Stator1 is wound CW and S2 is CCW, facing Armature...so, if we will energize them, they will both generate same polarity facing rotor.
This fact has to do with the way a Magnetic Fields vortex into Space...which eventually ends up by both Poles turning the same exact way...so both opposite coils will add up when connected in series, but, Hey, that is from "another chapter"... ;D
I start by Center Coil and winding outwards to next adjacent sub-coil, so, center would be Sub Coil 1, then SC2, SC3 and finally SC4...
Each Sub Coil have approx. 125-130 Turns, generating a Total Resistance whole Coil of 7.5-8.0 Ohms.
Some hints about winding these type of stator coils :
I built some copper wire Guides which will serve to keep wires all the way to the back of Stator Slot (very important), otherwise wires will start blocking the entrance for further winding (see Image Attached)
I may keep adding to this post later on "EDITS" at the bottom of this Post...as I have to move into the Brushes new arrangement following up...which was even more successful.
Cheers
Ufopolitics
EDIT 1: On the first image when I was ready to start winding sub coil#1...look at the copper guide front bent angle, and where it sets related to stator slot.
This guide settings will force wound wires to go all the way back on slot, as it gains height...and this will be very useful for further coils, to hold wire at the back of this sub coil#1...
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
...And so, after done with a Sub Coil...
You bend straight the front part of the copper guide angle...and pull them out (see image)
It should slide under the insulation paper...so, not scratching the enameled wires... ;)
Cheers
Ufopolitics
―Leonardo da Vinci
Ufopolitics
I have decided to migrate my Post from Holcomb Thread here...as I will show further developments in a near future:
A Brief summary...
We need to work more on our Developing and Research "Techniques"...As "enhancing" our "Powers of Deeper Analysis"...please, let me explain...
Yes, over the years we have being observing, reading, finding certain "anomalies" related to FE, and we have ignore them...or simply say "it was faked"..."a hoax"...
A very simple way to keep with the same B.S of Classic Sciences which have NOT delivered FE...and never will, unless We, as researchers, developers in the Private Sector...do it ourselves...
First thing that Clemente Figuera wrote, after succeding with his Patents back in 1908 was..."I never could have imagined it was so simple!!..."
Then Buforn tried to add "improvements" to Figuera Patent which was already working...and He screwed it off...
And yes, there has been "something" we all have been missing...to go deeper into it, to  study more and more..Magnetism, period!!
I mean, up to now, Science still have the ridiculous and rough,  "Iron shavings" as the only way to "visualize" a magnetic field...come on, please!!
After we all have Ferrofluids developed way back in time...after we all have Magnetic Viewing Film, after we have the Ferrocell  developed and patented by Tim Vanderelli, Books like Ken Wheeler "Uncovering the mysteries of Magnetism", awakening our ways to comprehend further on that beautiful Spectrum...
But we still invoke a few iron particles freely loose to "officially" understand how Magnetic Fields look like...Pathetic!!
Quote from: Feb2006 on May 27, 2022, 06:13:19 PM
What ufopoitics describing is new and game changing.
Thanks, Yes, this would be "game changing",definitively...beyond what ALL of You could ever imagine...beyond your wildest dreams...
I started playing with this tech a very long time ago...but, at that time, I was constrained (and may confess, also very stubborn) by the use of "Asymmetric Fields", and kept working for thousands of hours on the same, and only observing just a few "anomalies"...but nothing "galore"...so, I end up abandoning it...
Until I saw Pierre Cotnoir development, read all his posts here*...and finally realized where my MAIN ERROR WAS...The "Secret"...which is already out  and spreading...
Then I finally understood almost everything, not only what I was doing wrong...but also allow me to understand all previous FE Technologies shown before...like Steven Marks TPU...like Don Smith's developments...like Kapanadze...etc,etc
Not collapsing the Main Field...but harvesting it, feeding it, while mutating only minimal small chunks to stimulate a movement...a Rotation.
Now, How successful and How far could you get??...equals how good You put it together...depends entirely on your building skills, the tools you own...and the effort you decide to waste on it...
However, I disagree that this Technology is...New?...sorry, but I do not think so:
That many "knew" way back about this tech but hid it, seize it?...Yes, definitively!!
Why?...
First, because it will reveal how wrong our Science have been for hundreds of years...when it could have been built such easily...effortlessly...and demonstrating that it could be done very long ago...The COP>1, Overunity, Motion Perpetual, etc,etc...
Second, and that I consider even more powerful...is that this technologies will also bring Us Antigravity...and time will tell...by simply altering in a certain way the molecules of steel and other alloys in a way never done before, counterways alignments of high speed traveling magnetic fields rotations...will eventually render a very light material, which will levitate...defying our "Gravitational Laws" plus breaking all the "specific weights tables for each material"...
Third and final (main reason for banning it)...By learning to "manipulate" the Magnetic Fields this way...we could eventually build very powerful EMP's (Electro-Magnetic Pulses) "Tools"...which could also end up in the making of powerful weapons...like the "Death Ray", developed and Patented by Tesla...way back, or as putting together a small and compact "Portable Venus Shooter"...All these "things" could be very dangerous...in the wrong hands...
However, going back to our Analisys Powers...we are still "constrained"...in our way of thinking...a vivid example:
WHY in this World DO WE STILL NEED A "STATOR-ROTOR-STRUCTURE" (or simply put: a Two Part Generator) where the so called "Rotor" does NOT Rotate??!!...
I mean, this is really laughable at...¿¿ A "Stationary Rotor"...??...really?
I mean, seriously...Why do we still need a "Rotor" whole structure and configuration, surrounded by a "Stator" which does not rotate?...(thinking)... ;D
And so...why do we need a "Shaft" for a  "Rotor" that does not rotate...lol??!!
Bad concepts of "definition" applied above...which keep Us within the same loop, circling over and over...and part of that loop eventually keeps Us going back to the "successful apparatuses" which generates electricity by physically rotating a rotor (doh!!)...when ACTUALLY, there is absolutely no relation between the two systems whatsoever...
Why keep constraining to a completely useless "Rotor with Shaft" within a "Stator" structure?...when we all could move to a Full Static All New Configuration, which grants way more room and "comfort" to all windings and cores we will build in a near future?
I mean, do not take me wrong, I see it as a way to "start" a development with "things" that we all have "on hand"...however, start thinking about getting rid of all these no longer required structures, in order to give more room to more efficient and better engineered developments  ...for God's sake!!
All above sounds a bit too crazy, right?...
Or maybe "too ahead of these times"...
Ufopolitics
―Leonardo da Vinci
Ufopolitics
Quote from: Lunkster on May 28, 2022, 03:22:07 PM
Hi
I like what you just said about what things could look like in the future with free energy!
They are similar to what most FE researchers are striving for.
After you get the full operating FE systems running we
will all be excited to see it in operation.
So thank you again for all the hours that is being worked on it to
bring this technology to the world!
Lunkster
Hello Lunkster,
Yes, thank you, I  have duplicated my post here (for my own recall later on), which was originally posted by me on Holcomb/News/Thread
However, this Thread is only for Builders, who are or would be, willing to start a build based on my Main Topic and Development(s)
Although, I will accept some opinions or questions related to the build only.
All other posts related to general opinions, or just general comments would be removed.
It is ALL written at the beginning of this Thread
As I really appreciate your interest, I will please ask you to transfer your post as a quote to my last one (or as you like, without "quotes") on the Holcomb Thread (link above in blue) where I will respond about your opinions.
I will give you enough time, then I will delete your post here, plus my response.
I want to keep this Thread clean, so access to important data (for future builders) is available without having non related to build posts crowding it.
Thanks again for understanding and so I appreciate it.
Ufopolitics
―Leonardo da Vinci
Ufopolitics
Hello to All,
Here is a short video about testing two different Stators configurations...first was the previous one I have shown here, versus an overlapped one, using same amount of wire lenght...lesser turns, as each coilis same size...
VIDEO: TESTING TWO DIFFERENT STATORS CONFIGURATIONS
Ufopolitics
―Leonardo da Vinci
