The Lee-Tseung Lead Out Theory
Started by ltseung888, July 20, 2007, 02:43:44 AM
ltseung888
The Yu Oscillator gaining kinetic energy when passing through the magnetic actuator
http://www.youtube.com/watch?v=-u3fOwkiM7U
The Howard Johnson magnetic actuator set up.
An object can gain kinetic energy when it falls under the gravitational field.  A magnet should be able to gain kinetic energy when it moves under the influence of a suitably arranged magnetic field.  This does not violate any laws of Physics.
The Yu oscillator can gain kinetic energy when the magnet at the tip of the rod passes through the magnetic actuator set up.
Happy Chinese New Year of the Tiger.
WattBuilder
Hello Mr. Tseung,
Congratulations to you and your team’s terrific work over there.
Inviting scientists to double check your results shows a great deal of honor on your part.
Your Correct, The Yu Oscillating Generator does not violate any laws of Physics.
Happy Chinese New Year !!!
Sincerely,
Howard Yu
ltseung888
Quote from: WattBuilder on February 15, 2010, 12:02:16 AM
Hello Mr. Tseung,
Sincerely,
Howard Yu
The Yu Oscillator is unusual because the prototype was built with a large size â€" over 3 meters as a starter.  It is demonstrated as an oscillator or a pendulum at present.  However, there is Physics Laws forbidding it to be constructed as a large wheel.
If the device were in a wheel  form, there will be no need to reverse the magnets at the end of each swing.  The same magnetic pole will pass through the “Howard Johnson type actuator” at each rotation.  Kinetic energy can be gained.
The Yu device should also work when rotating in the horizontal position.  The leading out of gravitational energy will be zero.  But there is still the gaining of magnetic (electron motion) energy.  The gain can be via two mechanisms.  The first is the motion through the actuator.  The second can be the leading-out of magnetic energy in an appropriate magnetic field.  (e.g. David Hamel unbalanced magnetic rotation).
If the Howard Johnson type actuator works, the David Hamel type rotation of magnets in an unbalanced magnetic field should also work. (The late David Hamel was the inventor who claimed that he gained his knowledge from Aliens.)  One part of the Wang ShenHe device uses rotation of magnets in an unbalanced magnetic field.
Once we understand the above, we can replace the actuator with magnetic coil repulsion at the right time.  That is essentially the Tong Wheel!  It can be seen quite clearly that the larger the diameter of the wheel, the greater will be the torque (Torque = tangential force x radius).  The speed of rotation can be faster because there is enough time for the Pulsing Force to impart all its energy into the system.
Energy can be extracted from the axle.  From simple mechanics, the torque should be the same.  The energy from the axle is related to the torque and the rotational speed.  We can now increase both easily.  (The lack of understanding of the existing engineers is their not knowing Lead-Out Energy.)  Once they understand Lead-Out Energy, they can easily tune the diameter of the wheel, the magnitude and frequency of the Pulse Force and the rotational speed.  They can easily adjust that to suit the external load.
Lead-Out energy theory wins again in the case of the Yu Oscillator.  When a theory works in all the cases applied, it has to be right.  When it can be derived from the well-tried Parallelogram of Forces, it cannot be wrong.  Now we have the Tong Wheel open to all scientists for double checking and verification in Hong Kong.  Lead-Out Energy Theory will become Law.
If Lead-Out Theory is correct, mankind can lead-out gravitational, electron motion and other forms of non-polluting, readily available, inexhaustible energy to use.  Fossil Fuels will become history.
chrisC
WilbyInebriated
Quote from: chrisC on February 15, 2010, 08:09:00 PM
PIGS can fly!
cheers
chrisC
other than being juvenile, what purpose does your continual chanting of the same thing serve?
this thread is like pavlov's bell to you isn't it little doggie? it's so cute how you conditioned yourself... ::)
you truly are a pavlov's dog.
