Anty gravity, Energy Output versus energy Input.
Started by Creaform, October 23, 2007, 07:18:06 PM
Creaform
Wormholes rely on the idea of time being an editable dimension but time is not a dimension, time is a name given to the rate at which atoms react with eachother, hence there bieng only 3 dimensions, and wormhoels and paralel universes disapear in a puff of logic.
Now all i came here for is a formulae on antygravity.
and as for reaching the starts. Faster than lgiht travel is not easy without a massive power source. A powersource like say.... somrtihng with the destructive capabilies to destroy a galaxy?
All I need is a figure for my uni paper.
linda933
Spaghettification Effects:
http://en.wikipedia.org/wiki/Spaghettification
I believe you will find the information you need right here.   Marinara, Clam or Alfredo sauce with that, sir?
Linda
Also...accurate verifiable efficiency numbers on anti-gravity machines are very difficult to find.  It seems most of the manufacturers are reluctant to discuss this issue, which tends to make me suspect it is in the very low numbers.
BEP
@Creaform
Something tells me in order to do what you wish you'll have to employ the use of a naked singularity. When you build the thing please do us all a big favor.
Don't flip the switch until you are not only off-world but out-of-galaxy.
Good Luck!
Creaform
Spaghtification will not result because you will not be experiencing syntrifical force nor the bieng sucked into it force.
So the seporate sides of oyur body would not be feeliugn different forces
Nacked singularity?
Nope just an average everyday blackhole.
Power usage is not a problem. Theres allot of energyin a black hole over 2 solarmasses to be precise.
armagdn03
Hmmm, Id stop where you are buddy. I?m not trying to shut down your ideas or anything, but I realized a lot when I started to look at the fundamentals of what we call physics. This is what led me to the OU community.
Only 3 dimensions? Time does not count? I could definitely argue differently!
In fact, one could argue that time is the only dimension! In fact, it has been proven that a finite measurement like length is not finite at all. In fact the length of an object according to relativity is directly tied to the speed with which it hurdles through the other 3 dimensions. As you speed through the physical dimensions, you slow down in the time domain. The connection is there.
Now to really throw you through a loop think about this. Relativity teaches the student that we cannot know for sure if any one object is ?moving? at all. In fact movement itself is relative the viewpoint of the observer. So if you watch an Olympian throw a javelin, you may notice that it gets shorter due to its increased speed. But maybe the javelin is not moving. Perhaps the entire universe just moved around the javelin.
Maybe just by watching the man throw the long rod, you have yourself become shorter. This is why I cannot watch NASCAR, all those fast moving cars makes me relatively ill. I cant stand turning on the tv and start to instantly move 200+ miles an hour.
In fact since the meter is a fractional measurement of the distance between the north pole and the equator (1⁄10 000 000 the distance) and since the earth is hurdling through space at a constantly variable speed (which can be determined by the fact that our earth does not limit itself to a perfect orbit year after year,) one could argue that there is no such thing as an si unit of distance. Where are your three dimensions now?
Gone in a puff of logic.
I wish I could turn my brain off sometimes, then I could get some sleep.
