Single Wire Tests
Started by duff, October 31, 2007, 03:42:00 AM
eldarion
Hi Bruce,
I meant to ask a question about that simulation.  It looks like he has the two pulse sources, but what is that signal generator doing at the bottom of the schematic?  Is he feeding in another frequency?
Would be interesting to see...
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
Bruce_TPU
Quote from: eldarion on February 05, 2008, 08:21:32 PM
Hi Bruce,
Eldarion
Hi Eldarion,
I think it is an oscilloscope, showing the output   ;D (of Combined frequency's, identical, out of phase.)
Or I could be completely wrong, and he used another frequency there.
@ cOmster
The answer is??
CodeWebs
I've always thought about why SM would specifically use the term 'bailing wire' if there were not some transformer action going on there.  I believe that in the videos where there appears to be two rings placed vertically of one another that they are bother transformers.  The magnet is placed on one of these transformers only to cause a slight phase shift in the wave going through it.  SM eventually moved away from using a magnet to do this and that is why a magnet was no longer needed in the later devices.  It is this phase shift that by some means cause the two transformers to create the output seen.  Could the secondaries be connected to each other with diodes and the primaries be connected with diodes, and power taken off and put into each primary connected in series? The wave would travel opposite ways in each transformer slightly out of phase with itself and the diodes would keep the current flowing the correct way possibly.
BEP
@CodeWebs
Could be. That is as good a theory as any other I suppose.
Bruce,
That is an 'O' scope in the bottom. That SIM output is pretty bland compared to what should show.
That is usually the way SIMs go anyway. They don't usually consider the magnetic part of the circuit anymore than people do.
M@rcel
