Perpetual Motion Wheel Design (Quite Simple)
Started by Alexioco, March 22, 2008, 10:10:11 PM
Dgraphic911
Thanks for the insight, i sometimes wonder why noone else has done this and then i am reminded. Your thought process is great. Keep up the good work  ;D
Alexioco
Also, here is my wheel study
Weights at right angels (That Must Move) (Energy Rate: 1 - 5/Weak - Strong)
Single weights (That Must Move) (Energy Rate: 1 - 5/Weak - Strong)
Balanced weights (That Cannot Move)
Overbalanced wheels (That Must Move) (Energy Rate: 1 - 5/Weak - Strong)
Strength of Different Balances (Balance Rate 1 - 5/Unstable - Stable)
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
Dgraphic911
FreeEnergy
someone should try replicating this with working model 2d.
download your copy here:
http://workingmodel.design-simulation.com/WM2D/download.php
Alexioco
Quote from: Dgraphic911 on March 25, 2008, 01:17:44 PM
Have you done these on a wheel ????
No, I know from looking at them...
Best to make sure though :)
Also, I am going to try that link, I will try to make my wheel on it, anyone eles who knows how to use the progam want to try too? Seen as I ahve never used it...
Edit: Ok, it says the file is corrupt, but I can use /NCRC command line.
Then it says Not Recomended
Whats this then?
P.S
1. I am going to try them on a wheel now
2. I have some wood for my wheel to start
Ok I have tried them all, I got only 1 wrong and one a little miss understood so, not bad for just drawing them and knowing from looking, I must admit though, after testing them, I now have learnt more from them, there are many different things here to learn, if you combined some of these, you will surely get perpetual motion, some of these swing the wheel thurther than you would think, so by aranging and combinding weights with some kind of movement out of these tests, you might find it...
Now, if I look at my wheel, and compare it with my tests/studies, I can finally get an answer as to weather it will truly work, if not, then I can look at my studies and work off my wheel and improve it, by the way, I am happy to share this with you all, you may test your wheels using this if you like :)
Ok I just tested my theory below to see if my wheel has a chance of working, the answer is yes, but only just, never the less, it should work...
Wheel A did over come wheel B through its already existing movement...
(Look below to see the test)
This is how I just tested to see if my wheel will work
The Theory/Test
