Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
hansvonlieven
Quote from: Omnibus on April 20, 2009, 05:36:02 PM
@All,
Check this out. If I haven't overlooked something then that's it. And, let me add, if that's it then @eisenficker2000 rulez!
Another quirk of WM2D. The device cannot possibly work as drawn. If you imagine a vertical line through the axle you will see that there is more torque on the right hand side than on the left, yet the device rotates to the left. And that is without taking friction into account.
Hans von Lieven
Quote from: hansvonlieven on April 20, 2009, 06:00:17 PM
Hans von Lieven
I believe you are wrong. If you draw a curved line and do the torque analysis you will be surprised at what you get. Even though it's closer to the center its torque contribution is higher than the one that is further away. I posted the same answer in another thread;
http://www.overunity.com/index.php?topic=7262.new
Omnibus
Hans von Lieven
The question is why isn't the same quirk showing itself here (see attached)?
Omnibus
That link you gave is from the days when the basic flaws in wm2d were still unknown. In the present case there are no rigid joints, air resistance is on, there are no springs and we have a similar model (non-working) with everything else the same but the grooves on the rotor.
