Where will the energy come from, to run a Magnet Motor?
Started by TinselKoala, June 06, 2009, 02:06:20 PM
IronShell3d
Quote from: WilbyInebriated on June 07, 2009, 11:46:28 PM
assumption. the big bang THEORY is an 'extraordinary claim' with no evidence, ordinary or otherwise.
Hi WilbyInebriated,
So how about the theory that Iron was formed from Hydrogen in a multi step fusion process in the belly of our sun, then when it finally had a gut full of heavy atoms our sun went Nova and belched out all the heavy elements that over time formed the planets?
IronShell3d
IronShell3d
Quote from: newbie123 on June 07, 2009, 11:35:57 PM
I find it amusing how you're trying to push your theory here.    Someone can say anything and you'd probably  say...     "Yep...  That's right..  The spin and momentum are stored in the 4 unpaired shell 3d electrons" ..
Can  you explain exactly what this means?      I don't think you're talking relativistic properties, radioactive decay,  or  energy levels...  (and If i remember right, orbital electron spin is directly related the energy level)
Hi NewBie123,
What is it you object to:
1) The Iron atoms 4 unpaired shell 3d electrons are responsible, when aligned to other Iron atoms for the external magnetic field of a permanent magnet?
2) That this external magnetic field is composed by both a H field and a B field?
3) That the magnets H field can induce domain alignment in an adjacent ferrite?
4) That energy is required to overcome frictional losses in the ferrite as the domains physically rotate into alignment.
5) That this energy comes from the H field of the magnet.
6) That the magnets H field comes from the shell 3d electrons.
7) That magnetic fields are not energy sources but just transfer energy.
8) That the shell 3d electrons provide the energy needed in the ferrite to overcome domain alignment frictional losses via the magnets external magnetic field.
IronShell3d
newbie123
Quote from: IronShell3d on June 08, 2009, 09:00:27 AM
This is what have a problem with...       An  H field is not an energy source.   What physically moves that H field, is the energy source.
Until you can measure it, arguing about something can be many things.. But science is not one of them.
turbo
lumen
If you knew where the energy was to come form and how, then we would already have a working device.
The fact is, it's impossible until it isn't. At that time you will know where the energy comes from.
One can only test different principals and concepts looking for the one stone no one has rolled over. It is likely they have all been turned over!
