New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
wattsup
@gotoluc
Regarding the diagram you put up, shouldn't the output bulbs be in series given his higher voltage?
gotoluc
Quote from: wattsup on September 09, 2009, 06:49:40 PM
@gotoluc
Yes, I thought of that wattsup but wanted to keep it simple for now. However, this could be one way he could deal with the higher voltage output but we don't know what voltage rating his switching Capacitors can handle, so better stick with what works for him.
Luc
robbie47
Just a thought: has Ali's technique something in common with the testla switch method?
Instead of the batteries, 3 capacitors and a power source are applied?
Some corresponding text from PesWiki:
'Classic' Tesla Switch
The Tesla Switch creates a pulsed current flow between four 12v, Lead-acid batteries in an array (in the anticipated system, three such arrays operate together, or 12 batteries in all). Through some mechanism of radiant energy entrainment, net energy is captured within the battery system in this process. The rate of entrainment charging adjusts itself to the external load being drawn from the batteries; the greater the discharge to load, the faster external energy is captured from the active vacuum. The switching rate also determines the rate of charge, and must be kept in a range (20cps to 800cps, TBD) which, in relation to the [then] load, does not damage the batteries from excessive charge
N.B. I am not saying the Tesla switch is proven technology
Another interesting site on tesla switches by John Bedini: http://www.icehouse.net/john1/tesla.html
Maybe I am wrong but I see some similarity with Ali's siphon explanation as well with one of Bedini's pictures from that site
spoondini
The concept of the electricity 'siphon' has been twirling in my head for about 3 years now.  It's what brought me to this board in the first place.
Amazing to see that someone has potentially materialized the concept, exactly when I found the overunity board.  Serendipity.
Hat's off to you Ali!
lltfdaniel1
Quote from: robbie47 on September 10, 2009, 04:48:58 AM
Well all overunity systems share this method..it causes a water hammer cavity effect in the circuit and draws energy from the vaccum.
There have been people who shorted the circuit at the same time who got higher volts then that was used to power it.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
