The Tesla Project
Started by allcanadian, January 22, 2008, 05:56:53 PM
sparks
I'm having a problem uploading an attachment of a circuit and have tried to describe this circuit in a thread on electrinium to resonanceman.  So I'm gonna try it again here.
@Armegedon:  looks good.
  My idea was to set up an Lc network but use a Tesla cap/coil in series on each leg between the inductor and the main cap.  As the main circuit oscillates these thrucurrrent capacitors should alternately charge and discharge without effecting the oscillator.  The electrostatic field produced between these two caps would be interesting to monitor.  Bonus energy? I was going to use a small motor as the inductor in this circuit.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
barbosi
Quote from: armagdn03 on October 04, 2008, 07:18:29 PM
The first two pages of the talk are up...
Thank you armagdn03 for putting effort on this presentations and to Erfinder for hosting them.
armagdn03, I was watching these commonly known facts and reading your comments and I have to say you have the gift of highlighting simple things that escape to our interpretation.
And if you allow me, I'll try to make a small correction and I hope to take it as an interchange.
In your presentation you said:
This means that while one is at max, the other is at min and vice versa.
These could easily be labeled Voltage and Amperage, noting that while one is at min, the other is at max.
I'm sure you didn't meant exactly that but rather "when one is at its apex the other is at zero".
I attach here a snip from that picture taken from www.allaboutcircuits.com for reference. I would say that this particular little mistake made me reflect. It is at the apex of one wave when we have to notice the seed of the other. While one is "decaying" the other is "growing" and so forth.
I can't wait for your next material. Thus far I found your presentation very inspirational.
Regards.
When the Power of Love overcomes the Love of Power, there will be peace.
armagdn03
Keey eye, im glad people are paying attention.
Actually i mean exactly what I wrote. Max = apex, min = zero. if you would rather apply those words then do so.
f you were to view min as the negative apex at the other half of the cycle, then my statement would be incorrect. But the negative half of the cycle is really just a reversed copy of the first and its peak is another max,  and the same rules apply.
Try to equate it to something more familiar, thats why I told of the pendulum.
When it is on the up swing and changing direction, it stops for a fraction, at its higest point, or its max of potential, then as it hits dead center, its moving its fastest, or max kinetic, then the cycle happens again in reverse as it swings back up to its high potential position on the opposite side.
for further understading it is important to realise that the conditions all revolve around zero, and zero is min.
You can post here if you like, but i have also set up a new thread specifically for this in the tesla tech part of the forum, ill put up a link, but its easy to find
I wish I could turn my brain off sometimes, then I could get some sleep.
wattsup
@armagdn03
I would like to also thank you for your great web page and three videos. Very well explained and demonstrated effects of how resonance will modify or "vary" the resitance hence the energy flow through a circuit. This is giving me some great new avenues to explore and experiment.
As these demos have used an AC sine wave, do you think the same effect is possible with straight dc pulsing, or would there be required some type of DC sweep up and sweep down pulsing to create a similiar effet as the max-0-max, or does it absolutely require a DC sweep pulse/sweep reverse polarity pulse, etc.
In essence, if you have a signal generator that can switch between two pre-set sine wave frequencies
that are each a resonance of two different valued coil/capacitor pairs, your demonstration could be doubled in its effect. With three it could be tripled. Hmmmm.
Your method of explaining is both comprehensive and attainable and I would put this as a prerequisite to anyone potantial OUer. Thanks again and hope to one day see a page two.
armagdn03
The next episode will contain DC pulsing. Here is a hint DC pulsing works just the same except with harmonics.
Also dont try to double this effect, don't heterodyne etc, don't worry about any of that, MAYBE it could be done, but its not worth your time at this point. maybe try to build a motor off of it?
