Bedini SSG - self sustaining
Started by plengo, August 28, 2009, 08:04:34 PM
mscoffman
Quote from: bigface on September 03, 2009, 05:59:20 PM
why don't you guys use ammeters to measure how much power is actually being used by the chargin battery and how much power is absorbed by the others.  Or use a device that measures the instantaneous voltage and current every second or so and have it graph V*I of all three batteries.  The energy is the area under the graph.  Judging energy using only the battery voltage doesn't seem very scientific.
Don't forget that current is not energy just like voltage is not energy.
You can do this, but it is very tough to do without slowing the time
dynamics down so that the signal doesn't pulse. Removing the pulses can
be done with a buffer - a capacitor. The motor's nature is to be dynamic -
so what you have to do is drain some energy off as DC and measure that
excess. Once you have it, you adjust to drawing off as much as possible
and have the motor still run. This is your estimate which you divide by the
amount of time, known as the integration period, and start integrating
again for the next value.
To: Plengo
You really want your goal to be "Science" put before "Finishing
the Project". To do this you want the instrumentation and control
power supplies to be independent of the "core circuit activity"
until you have proven or have an estimate of how much extra energy
has come from the core circuit (/time). Reed relays and opto's can do the
isolation. This leaves the overunity energy intact in the core circuit.
Raw transistors don't isolate (especially bipolar transistor) so for this
part of the project you simply have the transistors drive reed relays,
that do the actual signal switching.
Now once you have proven,the overunity energy and approximately how
much, you can design the control and instrumentation circuitry with merged
power supply with the core circuit that use just the sufficient fraction of
what is being created...that has to take place before the unit is claimed
to be full overunity â€" but it need not be the first goal. It’s the overunity
of the core circuit that is important, but technically the control and
instrumentation need to be “paid for” from the core overunity eventually.
â€" leaving user energy.
By the way, the source and charge battery that are back-to-back you
might try placing power diodes backward across these batteries. Current in
one direction discharges one battery or the other and the extra diodes
would provide a  “non-discharge” pathway. (If it doesn’t break circuit
operation), that is.
It's very easy to convert an old spare slow PC computer, into a
process control computer, and it can be somewhat
easier to program in your favorite HLL,-then it is to program
a microcontroller. The input and output bits can then be read
and written into something called a Port Expander. I've done several
projects in this way and they are a lot of fun. If you can control a process
manually, then it's easy to control it by computer. Let me know if
you would like to do this and I can send you a port expander circuit
expandable to any number of Input and Output signal bits.
In the long term - gross battery voltage increases are state of charge
increases, but only in the long term - assuming the batteries are functioning
normally.
Also, if the circuit works as advertised then the control microcomputer
can be used to draw off the excess energy and dissipate it in a load
(while measuring the total amount). This will need to happen
by some method if it is functioning.
:S:MarkSCoffman
plengo
Hey mscoffman, great advices, thank you.
Can you post a quick drawing of what you mean with the diode backwards?  And yes I would accept your help concerning that PC communication "expander" and how to do it. It would really accelerate my project since I can only switch automatically today using a function generator and a relay and it is under a fixed timed pulse which is not at all optimal.
Fausto.
mscoffman
Quote from: plengo on September 04, 2009, 08:14:53 PM
Fausto.
See if I can do an ascii(or whatever diagram)
    Charge                     Source II
              1n4001           1n4001
The diodes blocks each of their own batteries but lets
current flow around it when the other one is driving.
This is especially important so that the charge battery
does not get hit with a drive pulse. The circuit will definitely
function differently though...In Bedini circuit the charge
battery is opposite polarity then the Souce because BEMF
(back from the wheel) is reversed. If the both don't
work one should then the other.
Ok, good! On the expander, I usually use PAL programmed array logic drive
circuit but I have done a pure 3 TTL IC integrated circuit version. An old PC
usually has RS232 signal connectors, which I use. Newer PC's would require
an available USB to RSR232 converter dongle adapter.
:MarkSCoffman
plengo
some updates: This week I got two boards from Groundloop that will help me with the microcontroller and voltage measurements. One board has the PIC16F84 (if I am not wrong) and has 6 opt-transistor for the switching of the batteries. The other board is for the voltage differential measurement.
I will have to study a little bit how to make them work and hopefully with Groundloops help I will have the code doing the measurement and the switching inteligentely.
I also purchased some more parts that are needed for this new system.
Meantime I have been pulsating my 3 batteries using a function generator and testing many different configurations. Some better than others. All numbers have been taken and the graph is simply intriguing.
I will prepare the pictures of those graphs and upload this weekend (when I have some time). They are, to my view, a mixture of success and failures. Many different configurations were tested on the fly but never I recharged the batteries. Final voltages on all batteries added is not above when I started 2 weeks ago. It is only 1 volts below.
So I guess I will have to get this automated thing going to have success in a more prolonged fashion.
Fausto.
Fausto:
I read through your thread and just want to mention a few things.
In this circuit B1 never gets charged through D1.  When I see a schematic diagram that is not too complicated I try to look at it and work out how it works in my head.  I think that is a good thing to do for everyone that wants to experiment with your circuit or simply follow the thread in detail.  I will leave it as an exercise for those that are curious enough to see why B1 never gets any charging energy from the spike.
When you do get a spike going through D1, the energy goes to two places, but it's hard to say precisely what the proportion is between the two.  The first place is the B2-B3 battery combination, where the spike will result in a small discharge of B2 ("helping" the spike), and a small charging of B3.  The second place is through D2.  I assume that you would consider it to be undesirable to discharge through D2 because that represents lost spike energy that doesn't charge any of the batteries.  That is another investigation - trying to determine if D2 is "stealing" your charging energy from the pulses.  Why do you have D2 in the circuit anyways?
For your microcontroller or PC-based control system, why don't you just keep it simple and just use it to program switching intervals in software instead?  You can do any timing you want and if you assume the system can demonstrate over unity, it has to arrive at some sort of steady state.  This implies that you don't really need to measure the battery voltages.  Of course you are already doing that with your pulse generator setup, but changing the timing for the switching over to a microcontroller or a computer would be much more "elegant."
Someone mentioned monitoring the fan speed with the sense line and that is a fantastic idea.  I am just not sure if you will still have a working sense line any more because you destroyed the motor controller board.  You could easily make an alternative sense line by picking up a signal from the spike itself, and connecting that to the microcontroller input.  Certainly the microcontroller in conjunction with it's on-board timers and the development software (or PC equivalent) could make an extremely accurate measurement of the fan speed or the pulse frequency of the spike, and this is indirectly giving you the net voltage across the three batteries in series.  However, I have a feeling that you want to measure the individual battery voltages.  If the microcontroller has an on-board A/D converter you should be able to use that to measure the battery voltages quite accurately through signal conditioning.
