Yu oscillating Generator ---- Overunity YOG Model
Started by WattBuilder, September 14, 2009, 03:19:15 AM
WattBuilder
Hi Kator01,
I have made some progress since the demo of the YOG’s one cycle video. The YOG is now modified and the lever too.
I was anticipating this question.
Both sticks are made of PVC pipe found at a local hardware store. They were both cut from the same piece of pipe. Both were weighed down to the 100th of an ounce. The stone and the drive magnet assembly were repeatedly checked, including the screw that holds it.
The masspoint is about 8 inches close to the neck of the stone and drive magnet.
Now remember that there was a gain about 15 inches. If the masspoint was lower it will show the gain less because the lever ratio would be less. For example 7:1 ratio is better than 4:1
One way to get the same effect of the gain in the video is to increase the mass point higher. But as you can see there is no way to increase the length longer past the array of magnets without hitting them.
Can you post this over at my main thread? As I would like to keep this topic separate?
I’m gland you like my video. I hope more people can get a chance to see it.
Cheers
Howard
My latest video http://www.youtube.com/watch?v=gekDM8vg16k
WattBuilder
Hi Kator01,
I’m familiar with shielding magnets. I think there are simpler ways then using a battery though.
As for the flux guide, I’m too not sure? That’s something I will have to look into.
I read somewhere that electrons flow, something like 500 times faster through iron then through air.
The more flux spins interacting with the opposing magnets flux spins, will allow for traction.
The more spins the better.
The iron would allow for more speed and concentration of the electron to flow but where? At what point does the opposing electron from the other meet?
Now one way to look at it is if the flux can go through the flux guide, passing it? Then they are sure to meet?
Another way to look at it is that electrons flow normally greater on the skin of a copper wire. Would the skin separate the electrons from colliding that will allow for traction?
Well, I really need better materials and test equipment. But I will look into it. The answer my just be as simple as just sticking a thin iron sheet over the two extensions and just measure it.  :P
Howard
WattBuilder
Hi Kator01,
The iron plate guide across the poles actually worked, it gained about 2 inches over the HJ array.
Howard
WattBuilder
Hi All,
This new array set up seems to out perform my previous array by about 6 inches. Its based on repulsive force is greater then attraction force.
I’m going to be switching over to this for future testing until better comes along.
Howard
My one cycle video http://www.youtube.com/watch?v=gekDM8vg16k
WattBuilder
Hi All,
Here is an experiment method to prove the Yu Oscillating Generator achieves overunity.
This method is based on the YOG gaining kinetic energy per cycle as it absorbs the energy from magnets.
The illustration attached shows, cycle end points that starts from “A” to “H”.
Whereas “A” is the start point and “H” is the last “end stop” point.
Start at “A” and face the drive magnet to the array. Then lock it in so it does not turn as it makes a cycle pass.
When the cycle ends simply mark the point. It should be somewhere around “B”.
From there re-orientate the drive magnet to face into the array again and lock it in.
Release it at point “B” and it should end around point “C”.
Repeating this process until you cycle to “H”.
You should see the mark points get lower and lower and that the YOG gains energy, lifting the weight higher and higher.
The reasoning behind this test is that the release points of the next cycle have an increase of kinetic energy and potential energy from the magnetic array. Therefore it will add on top of each cycle.
After this experiment one may view that everything else to work out on the YOG is now Negligible. In that it is just now a matter of increasing the scale. Whether you’re working out the method to orientate the drive magnet or working out the load resistance of the turbine. The ability to scale just makes those issues too small to be a problem anymore.
So there you go! You just proved The Yu Oscillating Generator achieves overunity.
Try it and see.  :D
Note: This test method has been confirmed on my test unit.
Howard
