The downfalls of conventional electrolysis - and how to fix them
Started by oswaldonfire, July 20, 2010, 11:30:31 AM
niofox
The place was closed when I left work, but I got everything this morning
1/2" PVC pipe, safety wear, 2kg Caustic Soda
Can't mix it until we get another sunny day however.  All rain this past week.
There's just no way I'm mixing this inside my stuffy place
Will be winding the coil when I get home.  Luckily I've got a 4-day weekend to get this thing running  ;D
I noticed I had the capacitor wrong in my previous post.  I'm actually using a 0.001 cap
Along with the resistors I already have I will be using a 1k for R1, and a 5k + 220 in series for R2
According to the calculator I'll get 126KHz.  Will prolly use my 5k pot in there to change the frequency if it doesn't work at first
sergenet
@niofox,
the pvc is supposed to be 1 inch in diameter. The half inch is just too small although ok if you just want to find out if the idea works. You dont need much solution to fill it up. Good luck.
Serge
dutchy1966
Quote from: Goat on July 29, 2010, 07:52:26 PM
@ All
Just found some useful info of a replication that didn't work...
http://www.chrismarion.net/index.php?option=com_content&view=article&id=100&Itemid=205
Perhaps this info can be used to eliminate some of the variables that don't work in the replication of the original experiment....
Paul
Hi Paul and Oswald,
Thanx Paul for the link.
I had a look at this experiment and to me it seems he does exactly what we are expected to do.....
What is wrong in this experiment?
@Oswald
Any comments on the experiment shown? Is this how we have to try replication?
regards,
Dutchy
gsmsslsb
Just tried it.
No joy yet. :( :(
I think with 1000 turns I may need more than 12 volts to get action.
The 100% solution is quite syrupy when pouring it.
Pulling 12 volt .17 amps = 2.04 watts may need to put more watts through to get action.
ramset
gsmsslsb
I'm going your route [lye syrup]
Will slap this rocket fuel silly with whatever it takes !
Still "Brewing"
This may have been posted already.
Hydrogen Magnetrolysis
http://www.sciforums.com/showthread.php?t=66598
Chet
Thanks Grandma
