Source of energy, Testatika
Started by Lycanthropist, April 13, 2007, 04:01:40 PM
andrea76
Quote from: Steven Dufresne on April 29, 2012, 09:20:48 AM
For me the answer to this is easy. Other than the use of radioactive material (which I hope isn't the answer) what else but energy from scalar waves could account for the videos we see of 3kW continuously coming from the 3kW machine or 100W from the single disk small machine? Assuming it's not a hoax of course. (I tend to use the term vacuum energy but it's the same thing.)
He could simply have been talking about one aspect of the machine. Since most people on seeing the testatika think Wimshurst machine where you do take electrons from the disks, he may have simply been saying that that's not the case with the testatika disks. That's the way I've always interpreted that. Plus, if you release the static electricity slowly then you don't get 3kW. Also, you had to supply the energy to build up that static electricity in the first place so that's not a solution as to how it works.
-Steve
http://rimstar.org/sdenergy/testa
If you see the video of dieter dienst (d.d.interview luzi cathomen) at min 3:57 he ask about the cilindrical object in front.the KEY of the device is in that component!!! probably bifilar coil drived with 2 frequency.the first machine  build of baumann in the jail is made from scrap material....The energy go down from the sky (remember the words of steven mark!!) and is colllectorized/ rectified from magnet and coil.only this.the problem is the correct frequencies for the magnetic collection.Started from electrostatic charge,run itself from motor drived with one part of the energy rectified from the upper cilindrical object (made from magnet and coil -like potentiometer- and 2 high power resistor for short out the spikes).the motor in the rear side probably had the armature build of aluminium for reduce the focoult currents.if you oriented the machine E/W it stop to work.WHY???? .........
TheOne
Quote from: andrea76 on May 02, 2012, 05:12:52 PM
If you see the video of dieter dienst (d.d.interview luzi cathomen) at min 3:57 he ask about the cilindrical object in front.the KEY of the device is in that component!!! probably bifilar coil drived with 2 frequency.the first machine  build of baumann in the jail is made from scrap material....The energy go down from the sky (remember the words of steven mark!!) and is colllectorized/ rectified from magnet and coil.only this.the problem is the correct frequencies for the magnetic collection.Started from electrostatic charge,run itself from motor drived with one part of the energy rectified from the upper cilindrical object (made from magnet and coil -like potentiometer- and 2 high power resistor for short out the spikes).the motor in the rear side probably had the armature build of aluminium for reduce the focoult currents.if you oriented the machine E/W it stop to work.WHY? ??? .........
Maybe its so simple that no one thinked about it, see that, its not related to testatika, http://www.angelfire.com/ak5/energy21/capacitorcharger.htm
but after re-seeing the [size=78%]video that stephan put today on youtube, I got this light up in my brain :) and re-thinking about it, I think all the small cylinders are just like car ignition coil that take up the high voltage and the current drop voltage and with the back-emf are returned as current, now how its connected its maybe as simple as this drawing from the link. Just the negative static side on the negative side of the coil and the positive static charge on the positive side of the coil, but as well something like a sparkplug or just spacing between wire to generate the spark. This can be all together in the small cylinder, the big cylinder are just big caps that is used to make the wheel turn using the current from maybe just one of the coil.[/size]
[size=78%]
[/size]
[size=78%]
[/size]
gauschor
That is indeed an interesting article. That said, I have also tried to pulse a battery with sparks from my electrostatic device, but it wasn't successful in charging up the battery. Maybe I should have tested longer. I mean, there must be some truth to it, if it worked dozens of years ago. I also didn't use a large coil, but directly pulsed it from the Wimshurst device. Now I think the energy was way too less (maybe around 2 KV per spark and probably the charge had only pico or nano amperage) too charge the battery. A large coil would build up much more charge and would deliver much higher amperage per discharge. Obviously this is necessary anyway to charge a battery. I've read recently that today's battery chargers all work that way, like brutal stoneage: the device with more energy pushes its charge into the other device. So yeah, it actually makes sense to have good long antenna which will discharge a huge load and pushes it into the battery.
Though if the principle of the Thestatika was based on this they must have configured and perfectionized in remarkable way. For all in all the battery in the above mentioned article took at least 2-3 days to charge up again.
TheOne
The article is good, I think its possible to do something on the line with a Wimshurst, I will for sure try it this summer but to many stuff to do right now, need to do one thing at the time :)[/size]
[/size]
With Wimshurst, I don't think you need a battery, the idea is to self run the device at first using sparkplug/wire space, ignition coil and caps, the testatika is a big device, its should generate a lot of static charge, I dont know the energy you can extract from it, maybe some but I dont think all the town where the testatika is located, is powered by only one machine, I beleive one can generate less then 1kw, prob few hundred watts. Unless they have made a very big one and the smaller one was just to show...[/size]
gauschor
Some years ago I made a Wimshurst (actually not a Wimshurst, but a Toepler device with 1 disc) , which had 8 or 16 iron plate segments on the rotating disc. The plates were quite large with about 10x16 square centimeters. If you got electrocuted by touching this plate with a finger the pain was much stronger compared to my other device with small segments only. It really hurt, so be careful. The lightnings were only very short but once you saw it discharge you got a very thick intense lightning. I guess this would have charged up a battery.
It is as someone else described:
small segments create higher voltage / less amperage
large segments create lower voltage / higher amperage
Unfortunately the larger the segment is, the longer it takes to charge it. I wonder if this is essential in regards to the Thestatika: if a large coil is better to hold a charge or if you use metal sheets instead? I am not sure what they used in the Thestatika... sometimes it looks like they have huge coils in their mysterious cylinders, but on the other side it is told that had multiple perforated (copper?) sheets within these cylinders. It would actually make sense to use metal sheets only, because it would deliver more amperage. The one thing that is mysterious is, how could they charge the sheets so fast?
