High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
IronHead
d3adp00l Thanks you and keep watching  I think a few builders will help with your data search in time. There are some very good builders here and analyst as well. Forget what I am doing ,lets see what the builders on this page are doing and they will set the standards. Then maybe start  competition  to go far beyond the standard set.
hkyle  A+  absolutely right
IronHead
kokomoj0
Quote from: d3adp00l on June 11, 2007, 11:13:02 PM
Next, response to Koko,
@koko absolutely great math homework, there are a million ways to run the equations, BTUs, mole calcs, energy density conversions, but the answer always comes out relatively the same. Mathmatically using only HHO it would seem that things can't be done. Seems being a key word. A major counterpoint to the math is there are a few videos showing engines running with alot less than a swimming pool worth of gas. And that is what gives me the hope. So like grumpy and IH say just build and see the results.
NO not at all!   i was not trying to imply it would not work or could not work.   to the contrary if you read back about some of the things IH said he was going to add like vacuum, pulses etc etc i knew there was much more to come!   i suppose i should have been more clear, if you read in the doe report, he already is getting full cycle generation and burning in an ICE with better percentages than the doe states is possible for "just" hydrogen production alone!
i put that math up there as a reference for sizing stuff etc...  math helps me to correctly get the sizes right first time out of th ebox.   i hate ripping things down and starting over on projects so i always try to get them as close as possible to my application straight out of the chute and thought it may also help others to do the same.
hkyle
It?s easier to be forgiven than it is to get permission....
hkyle
Just got back from the fishing trip...fun fun fun...anyway where are we...high voltage and pulsing. Got it...I need to acquire some components for the Meyer VIC...small things...But there is no way right know I can throw 400v @ 10 amps into a cell. I will hang around get the circuit together check in...Try and build a coil stuff like that. I just might pm you about the coil though...but let me try first.
Quote from: IronHead on June 11, 2007, 11:23:18 PM
And your all going to crap your pants when I show you a 40,000 volt HHO system
But lets stay on the low low for now
IronHead
IronHead
Then put 100vdc  to the cell or what ever you have have and study it. then tell everyone what you found
