gotoluc
Quote from: synchro1 on March 06, 2013, 05:29:56 PM
Leon Dragone outlines the very simple nature of his electrical 'heat pump'
effect. His system consists of nothing more than a coil, a magnet, a power
supply, and a switch. He places a permanent magnet within a copper coil and
energizes the coil so that the external field of the magnet is
removed/compressed from the space around the magnet, without changing the
polarity domains within the magnet itself. He then employs an arc switch
(simple contacts) to quickly disconnect the power supply from the coil, and
leaves the coil open circuit. Suddenly the field of the permanent magnet is
free to expand back out to its 'normal' geometry around the magnet. But the
process of expanding this field requires work. The coil is open circuit, so
the energy can not be drawn from current in the coil. The field must
reinstate itself. Energy is drawn from the vibrating molecular domains
within the magnet, causing a measured drop in temperature of the magnet.
Essentially, ambient heat is transformed into work to reinstate the field.
Any inductive load applied while the field is expanding/relaxing is driven
by extraction of ambient heat energy from the surrounding enviroment.
Dragone claims to have measured experimental system energy gains on the
order of 20:1, using this approach.
I wonder if this is what Magnacoaster (Richard Willis) found?
Interesting ;)
Thanks for sharing
synchro1
The following's the abstract from the Magnacoaster Patent. Identical to Leon's Magnet Pump in construction:
"An electrical generator comprises an induction coil having a first end and a second end. There is a first magnet disposed adjacent the first end of the induction coil so as to be in the electromagnetic of the induction coil when the induction coil is energized, and for creating a magnetic field around at least the first end of the induction coil. There is also a second magnet disposed adjacent the second end of the induction coil so as to be in the electromagnetic field of the induction coil when the induction coil is energized, and for creating a magnetic field around at least the second end of the induction coil. A power input circuit portion provides power to the induction coil. A timer is disposed in the power input circuit portion for creating electrical pulses and controlling the timing of the electrical pulses to the induction coil. A power output circuit portion receives power from the induction coil".
synchro1
Check this new Lenz delay video out from MrAnguswangus:
Output coil adjacency raises gauss levels in each and other coil through mutual reinforcing "Field Lock.". The PMH background field reduces Lenz delay threshold propulsion R.P.M. These Leedskalnin coils, reverse wound to one another, generate a strong background field in attraction. This strong background field interferes with the rotor induced output coil magnetic pole shift interval, and creates the propulsion lag at lower R.P.M ' S.  This is the same effect I get with the diametric core magnets, minus the Magnacoaster output. He's setup to neasure his COP in horse power.
Reconnecting the horseshoe laminations with a small pancake coil in between to regulate magnetic density in the output coils, would help control delay threshold r.p.m's. The question remains wether or not additional pairs of ridgid field reinforcing pole shift dampening coils would help or not.
http://www.youtube.com/watch?v=JTXV3tURiH4&feature=em-subs_digest&list=TLtuh4M0PVF_4
crazycut06
Quote from: synchro1 on March 09, 2013, 09:58:16 AM
Output coil adjacency raises gauss levels in each and other coil through mutual reinforcement, and reduces Lenz delay threshold propulsion R.P.M. These Leedskalnin coils, reverse wound to one another, generate a strong background field in attraction. This strong background field interferes with the rotor induced output coil magnetic pole shift interval, and creates the propulsion lag at lower R.P.M ' S.  This is the same effect I get with the diametric core magnets, minus the Magnacoaster output. He's setup to neasure his COP in horse power.
Im amazed that he can still get speed underload even if the core is divided into two? Wonder if the effect is still present if he move the coils 180 degrees apart?
DeepCut
I've searched his channel but can't find a video of a test i'd like to see, the rotor speed with no coil/core present. I must message him.
DC.
