Proof of concept - perturbing a static magnetic field
Started by bob.rennips, May 30, 2007, 12:57:25 PM
Earl
Hi Bob,
yes, you are right several capacitors right at the supply pins of the driver IC are necessary.  I suggest 1nF, 10nF, and 100nF with the smaller capacitors closer to the IC pins than the larger values.  Also a few uF of tantal will not be negative / attention to correct polarity of the tantal capacitor.
I suggest a trifilar winding for the first experiments, two coils for injecting pulses, and one coil for the output.
Remember the polarity of the pulsed magnetic field adds to the field of the permanent magnet.
It is not clear whether some exact sequence must be used or whether a quasi-random sequence generated by linear shift registers will suffice.  I will soon post some information concerning random bit generators.
It is even possible that pulsed magnetic fields can shock the aether even without the pressence of a permanent magnet?
I think the best step forward is to start experimenting and see what happens.
Regards, Earl
starcruiser
Well I finally have a day off and I am winding my test rig, so I should have something to report soon.
@Earl,
From what I read in the patent, the voltage/power is derived from the differential of the pulses, i.e. one set at say 500v and the other set at say 350v, this would provide a difference of 150v.
The patent did mention sequential/synchronous and async pulses would work. I am planning on using async pulses to start, leveraging a blocking oscillator designs that uses the control coils as part of the oscillators circuits. I will be using 2 oscillators initially and plan on adjusting the drive voltage to adjust the output pulses voltage.
My initial design will use a 12v battery for testing and a voltage divider to drop the   source on one oscillator to say 9v while the other oscillator uses the straight 12v, this should provide the difference required.
As far as the magnetic field source, I am planning on using both a coil on the test rig for the source then replacing that with a neo magnet to see what results I get between them. I was wondering if the magnet is being used to couple the 2 air coil transformers. This will be another test for the rig as well.
There is some information on blocking oscillators that mentions designs that allow one oscillator to be sync'd to the main one and with careful capacitor selection would allow a frequency divider action to occur between the two. I am wanting to try this out as well. This will be the sync'd option I mentioned.
So first step is to build the test rig using 3 or maybe 4 coils per set on a 1/2" PVC form (pipe) and wrap 2 sets spaced 1" apart to allow for coil separation (reduce field coupling) and allow testing the Neo magnet theory. The use of the PVC pipe will allow insertion of various materials for potential collectors as well and this angle will be tested as well.
All of these ideas will be using as part of the testing a diode and capacitor to capture the radiant energy from the output of the coils for power conversion.
These thoughts are partially based on the SM open TPU design.
Well it is off to the hardware store to pick up a few items to wind the test rigs, I will be making a few of these rigs to test a couple of variations. Will report back later. Lots of variations to test.
Carl
karl
Quote from: starcruiser on June 14, 2007, 02:54:34 PM
@Karl
From my take on this patent the control electronics (I assume this is what you are speaking of) indicates an amplifier and a randomizing generator to change the levels of the pulses.
The main theory as I see it is to pulse the magnetic field (either permanet or electrically induced) and gain amplification from it by maybe tapping the ether.
Sharp gradients or pulses are required (sharp rise time, or on/off if you will) to generate the effect. The output is derived from the pulses voltage delta (the difference between the high and low pulse values).
We are looking to determine if this actually does work by performing the build of a similar device but using a control system to deliver the required pulses. The control systems we are thinking of will be synchronous as well as asynchronous, the patent stated either will work, so some are pursuing one path and others are pursuing the other. I myself am pursuing async pulsing using a blocking oscillator design using the control coils as part of the oscillators design.
I say have a go at it and see what you get if you are so inclined.
Hi Starcruicer,
here is the fiddle for your concert.
  Re: Proof of concept - perturbing a static magnetic field
? Reply #41 on: June 06, 2007, 11:16:40 AM ? Quote Modify
Hello Finders,
what you want to do is building a kind of stationary newman machine.
Have a look at the newspage of Stefan.
Someone has attempted a good example again. A working model out of nothing.
The main part of this kind of negative energy collector is a spark (plasma).
No discrete parts are used as diodes, transistors and so on.
Stefan has postet this 1998 at JLN labs site http://jnaudin.free.fr/html/NMac1118.htm
This machine consists basicly of a big coil (the bigger the better), a tuned sparkgap and a blocking device to direct the backward current.
At the right tuned distance the color (frequency=E-Level=tuning) of the spark change from blue (discrete spectrum, maybe a line of oxygen) to white (full (most)spectrum) and is making a hissing sound.
This is the electronic-hit-part of the future and the past.
The Teslas use different discharge tubes filled with H2 or N2.
I've found such tubes some time ago at ebay.
The are used to work in front of wimhurst machines (is a light going on in your head?) to show different colors of discharging gases.
This is the real tuner.
H2 has a continious spectrum!
H2 is receiving a continous spectrum!
The sun is sending out a continous spectrum!
Evey particle is tuned in a continous spectrum.
Every Molecule could be replaced by a frequency (actual science: Using frequency as catalysator).
Thats it.
The cat is out of the house.
The mice are dancing on the table.
So what I mean Stefan and all other finders:
This is a kind of tuner for a special spectrum and a kind of coupler between discrete energy levels (light to electrons and backwards).
You know that plasma is called the fifth (element) state of energy.
Most of the materia of our cosm is in plasma state.
You want to couple in this mass. The best universal and universallegal way to fullfil your wishes.
!This are just suggestions. I'm not a proofer, but think about it!
Please open your minds and start to see: over unity is only possible by thinking on cosmic levels. Oder ist das nicht so?
Every particle in the 3d space is affecting every particle in the 3d space.
Simply by overlapping all influences of all roompoints we get the momentary situation in static and dynamic fields. This is the basic of our common computersimulation programs.
The biggest mass is in plasma state. The biggest content of energy (gequantelt oder nicht) is sending out energy because of the fact, that plasmatic materia has more energy as motion, and therefore heat and preasure and speed, as materia which is resting more in one roompoint.
Is this clear?
We should couple to this mass of frequencys by sending out a em pulse with our coil (creating a vacuum) and receive a modified pulse (filling the vacuum) after a while.
Stefan: is it possible that we change the "Verweilzeit", the time of duration of our pulsed mass in the space and therefore the time of the em-Quant in space by adjusting the sparkgap?
Is the energy quant able to collect energy and mutate to a harmonic em object which is rejected by the coil (blow-suck-effect)?
Yes, I think so.
PLEASE READ THE PAGES 37 FF OF THE ATTACHED .PDF
It's the Patent from the most famous Scientist. Thats the Key to all FEdevices.
Thats the way.
The generator consists of two C's and one ore two L's with HF Ferrites, AMCC prefererd.
Meyer, Kunel, Morray, Tesla, ever and ever the same principle.
But the basics are here and search for my last mails, all books about that physics are free to download at the postet sites.
But I'll show you the sites if you can't find them.
Green technology with 100% positive energy respond.
and think about my words again
Best wishes to all.
Kar Funkel
karl
Good Morning,
who knows Dr. Aspden?
Here is the theory and practice of all! OU phenomenas.
http://v3.espacenet.com/textdoc?DB=EPODOC&IDX=GB2390941&F=0&OREQ=1&&CY=ep&LG=de
This Patent includes further Information how it works.
Fasten your seatbells...
All Books and papers from Dr. Aspden could be free! downloaded from:
http://www.aspden.org/books/Booklist.html
Please read all..
All Energy Science Reports are here for free! download (sparky or not, there is everything)
http://www.aspden.org/reports/reportlist.htm
His Newest Book could be downloaded free! here or buy it
http://www.aspden.org/books/2edpoc/2edpoccontents.htm
What do you need more to end your discussion.
###Step in FREE NRG###
karLfunkel
kames
Quote from: karl on June 23, 2007, 04:48:04 PM
Good Morning,
Please read all..
karLfunkel
@Karl.
I tried that patent about 2.5 years ago (right away when it just appeared on the web) with 20000 V setup. It didn?t work. I liked all of the Aspden?s publications and was following him very closely. I also tried to play with it by changing the configuration in some little different ways. The result was zero.
I read almost all Aspden?s articles publicly available.
Sorry, if I disappointed you.
Kames.
