Bashar's Spacecraft Engine
Started by teratologist, November 20, 2013, 04:21:16 PM
Hope
This is the first and second articles found so far,  not that they are matches for this work.  But these works ARE using principles that are not known commonly.
http://www.nrgnair.com/MPT/zdi_tech/tesla/TACREG-1.htm
http://www.rexresearch.com/gritskevich/gritskevich.htm
The main processes in GT-HMD are:[/size]
A principle of Van de Graaf's electrostatic generator, where the solid insulating tape was changed to the liquid one;[/size]
A perpetual washout of the surface electrons from the spacer layer takes place;[/size]
A single-turn low-frequency generator works as a coaxial turn with 4 resonance points and energy carrying substance inside it that has very high resonance properties;[/size]
The electrostatic breakdowns of cavitation-vacuum structures in water take place.[/size]
"The polar liquid (pure water) consists of dipoles only, i.e., strictly oriented charged molecules. During the interaction of ionized pure water with the layer of BaTiO3 the electrostatic field of above 10 million volts/cm is formed. During this process the breakdown of physical vacuum takes place."[/size]
I am going back to Mr. Aliens words and use them as keywords for searches.  This maybe exhaustive but insightful I hope.   (In the one link there is a 4 contact reference, interesting it would be put that way.)
Also going to do a search to see if I can find out what the bedrock depth was in Wardencliff and of what type rock it was.
I am going to relate some of my past as best I can recall it because it maybe be will show how quartz is very active.     Once my uncle took about 5 of us kids down past New Auberry, California towards the north a few miles to a piece of property on the west side of the road.  We gathered white rocks (not flint) with crystal structure and lined the entire bed of the old ford truck (metal with a wooden metal strapped bed) with maybe 2 layers thick of this "quartz" rock (rock was just laying all over the area).   We had fun messing around as kids do until it was getting late enough we could see it was sunset and getting dim light.  We all piled in the bed of the truck and my uncle Wayne Nance drove back up the dirt road as the rock giggled and wiggled blue sparks danced all over the place, kind of looking like it travelled as waves in a water pond.   We all of course were afraid, but soon calmed down when we realized it did not shock us.  Every bump produced an array of visual spectaculars that we kids all were entranced to watch.  Wayne and us took the rock out of the truck at his place on New Auberry Rd. and he used it to trim his garden borders.  Not a common thing to see,  but it did "spark" my interest about science a bit.   I know it must of been piezoelectric effect of some sort.  But how does quartz work to do that? AND is that the filter or action we are going to use in this device?   Your opinions and speculations please!
WTF
Obviously I can only guess how this works, but how I see this working is the wire net picks up the energy, which then resonates the crystal with the energy penetrating through it, which also probably amplifies this energy, then gets transfers to the rod then to the domes. Of course this could be completely wrong.
Hope
Ok,  after reading numerous geology reports on Shoreham Long Island (Wardenclyffe area) it has show there are many quartz deposits.  Tesla sank (rooted) his tower with metal beams 300 feet or more into that earth so he could "shake the earth" there.   Hope this means something other than what "shake" meant.  Of course shake could very well mean resonate.
WTF
I never realised the tower went 300 feet underground, I thought it was about 120 feet in the ground and nearly 300 feet above ground. I stand corrected.
e2matrix
Quote from: Hope on January 19, 2014, 02:50:48 PM
Have you ever taken a Wintergreen Lifesaver and bit into it in the dark in front of a mirror?   Give it a try sometime.   Here is the explanation for that and possibly something similar with your quartz rocks:
Why do Wint-O-Green Life Savers spark in the dark?
Actually, all hard sugar-based candies emit some degree of light when you bite them, but most of the time, that light is very faint. This effect is called triboluminescence, which is similar to the electrical charge build-up that produces lightning, only much less grand. Triboluminescence is the emission of light resulting from something being smashed or torn. When you rip a piece of tape off the roll, it will produce a slight glow for the same reason.
Triboluminescence occurs when molecules, in this case crystalline sugars, are crushed, forcing some electrons out of their atomic fields. These free electrons bump into nitrogen molecules in the air. When they collide, the electrons impart energy to the nitrogen molecules, causing them to vibrate. In this excited state, and in order to get rid of the excess energy, these nitrogen molecules emit light -- mostly ultraviolet (nonvisible) light, but they do emit a small amount of visible light as well. This is why all hard, sugary candies will produce a faint glow when cracked.
But when you bite into a Wint-O-Green Life Saver, a much greater amount of visible light can be seen.
This brighter light is produced by the wintergreen flavoring. Methyl salicylate, or oil of wintergreen, is fluorescent, meaning it absorbs light of a shorter wavelength and then emits it as light of a longer wavelength. Ultraviolet light has a shorter wavelength than visible light. So when a Wint-O-Green Life Saver is crushed between your teeth, the methyl salicylate molecules absorb the ultraviolet, shorter wavelength light produced by the excited nitrogen, and re-emit it as light of the visible spectrum, specifically as blue light -- thus the blue sparks that jump out of your mouth when you crunch on a Wint-O-Green Life Saver.
