AVENGERS
Hello to all, please look at these pics, and let me know whats wrong before I put 4ea. 9volt batts . Hope it works.
AVENGERS :)
marathonman
Quote from: RandyFL on May 18, 2014, 09:57:29 PM
18 May 13 / 21:32:05
Hello All
A few months back ( before the Xmas Holidays ) I built the Figuera's circuit that was on Patrick's website...I got the 555 to fire 16 LEDs then switched down to 4 diodes and power transistor and got the circuit to fire into a radio shack transformer ( I switched the transformer connections ) instead of using the transformer as a step down I reversed the connections and used it as a step up transformer... I was powering the 555 with a Best9 volt battery and got 1 Volt AC from the transformer... I was satisfied with the circuit and was going to finish up a previous planned house project before coming back to the circuit...upon completion of the house project I noticed an update on the Patrick website stating...        "It is essential to construct each of the cores of the electromagnets from iron and only iron. While a laminated core does minimise eddy currents, in this application, a laminated core has a major negative magnetic effect (something which is not generally known)."
Could someone elaborate on this...
All the Best
RandyFL
Randy;
This could have a lot of merit as the late Robert Adams (Genius) came to the same conclusion that solid iron cores were the best way to go so if any one has information pertaining to this subject PLEASE disclose. solid Pure iron does have very little hysteresis/Remanence and this is what is used in huge electromagnet for picking up scrap iron/steel.
we are ALL tired of our sick disgusting Local, federal government and corporations dictating influencing our very way of life otherwise we would not be here.
be free, act free and disclose.
NRamaswami
Hi Marathonman:
In India soft iron is cheaper than laminated iron core. Soft iron is more magnetic than laminated iron. I do not know why. Similarly as you go to higher voltages the efficiency of power produced in secondary increases. Soft iron appears to have lower eddy current losses at high voltages but I have no means of measuring eddy current losses. I'm actually not prepared to go beyond 350 volts in secondary but it appears we need to go above 500 volts to get reasonable outputs. I do not have skilled hands and the budget and the space to do these experiments now. I have gone up to 300 volts and obtained 91% efficiency on loads on an input of 220 volts and 15 amps and an output of 300 volts and 10 amps and lighted 14x200 watts lamps very bright. But it was not a Figuera design but rather my own tests of my own design but the material used for the core was soft iron rods which are tightly packed but had air gaps in between them and so must be considered very inefficient. But if you ask me why this happens etc, I have no way of answering such questions and I do not have the knowledge. I'm not sure if the centre core posted in the picture above your post would work. I have not tested it in the way it is shown but it is possible the secondary may not work at all.
tturner
any ou replication from this device yet? this devise intreged me for a while now just dont have much time to work on it
marathonman
I think Pure Iron means better transfer of Flux ie ..better or easier transfer of MMF between Atoms,  that and solid cores means More Atoms in alignment  to transfer more MMF at one given time than of laminated GOES. i am using almost pure Iron electrodes that are thick and have had great initial test but need to finish building my cores, can't wait to merry it up to my timing Boards. i have finished my two channel board and am in process of finishing the nine channel board. will show pics soon along with progress. God this new job is killing me but i will be taking over the whole Industrial painting Department then i will have more time on weekend to finish my Figueras device.
Be Free, Act Free !  (You gatta love Figueras)
