1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
havuhung
Quote from: gotoluc on June 21, 2014, 02:20:06 PM
Not with the mechanism you suggested!... did you know it needs 2 drive gears and going in opposite directions for it to work?... guess I trusted it would adapt to my single gear and didn't realize until 16 hours of building and after I installed it.
Here's the video: https://www.youtube.com/watch?v=-e8jUYrjOAU&feature=youtu.be
I'm going to be taking a break as I've been at this for 13 days straight 12 hours a day.
Luc
Hi gotoluc,
video clip I found: two disks to provide power should rotate in opposite directions, you have reduced the need for complex gear, now you give (part of the disk) is used to keep the lever arm and also is helping to reverse, and it will still work as required..
Well done!
Yes, somehow all available materials to carry out the work it is a top priority because it helps us shorten the time for test machine.
ARMCORTEX
Quote from: havuhung on June 22, 2014, 01:55:32 AM
Hi gotoluc,
Well done!
No apology ?
Silence you cretin! As an armchair engineer you are fired!
You wasted master Gotoluc's time.
havuhung
Quote from: Artoj on June 21, 2014, 06:34:35 PM
Hi Luc,
I can see you got into a jam. This design should work (no guarantees) it is a slight modification from my Hyperbolic Drive design, it will produce ellipses and many other interesting permutations from eggs to all form of hypercyclic shapes and patterns, the requirement would be a variable speed on the second sprocket/gear/pulley/directdrive. I have drawn it as a 1/2 speed form, which gives an ellipse, this would be easy to adapt using chains etc. The original Skinner design would be very similar to what I have here. The drawings are quick sketches, just adapt your materials to suite. I hope this helps with your build, regards Arto.
Hi Artoj,
there are plenty of clips for creating simulated the elliptical motion on youtube and (google) many of them are textured with gears!
Of the mechanical structure in your drawings are very good, there is stability, avoid swinging the arms while working.
Thank you
havuhung
Quote from: ARMCORTEX on June 22, 2014, 02:09:37 AM
No apology ?
Hi ARMCORTEX,
Not true as you think!!!
like myself, do not have conditions to test device! . . A friend of us a lot of effort to do the job too! I think all of us should have the support, albeit spiritual encouragement!. . Step in to test for any device, we will spend a lot of money and effort, it is not easy for everyone to be able to do that! . . From these results bring to a failure or not as desired; we gradually achieve success! . .
I never jealous of anyone!
