Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
kolbacict
QuoteIn order for me to evaluate this I'd need to know at what temperate and pressure
The pressure is atmospheric. Temperature cannot be measured with an electronic thermometer, RF interference.I will find a suitable glass thermometer, I will inform you.
https://en.wikipedia.org/wiki/Masaru_Emoto
Do you believe that water changes with thoughts?  :)
A powerful HF generator with which we heat water has modulation. If this can be done by thoughts, even more so by direct impact on water. Ask the water to decompose into its components into the microphone. Or pray ...
h20power
Here's what I am getting at. As seen in the attachment is the "Phase Diagram" for water. It shows what the conditions of water at different temperatures and pressures and if the molecule is in a gaseous, liquid, or solid state. We always have to keep these things in mind as I do believe it also has a effect on water decomposition. This is why it is so important to not put any heat energy into the water bath which the properly balanced waveform will accomplish as we don't want any energy being wasted heating up the water. Water is also effected by temperature concerning it's dielectric constant which is Meyer states the temperature when he talks about water's dielectric properties as seen in the pdf file in the second attachment.
This is why I make sure and tell people this technology is on the complicated side as it's the opposite of electrolysis which by contrast is very simple.
Shalom,
Edward
kolbacict
good diagram.  :)
I was wrong.  The thermocouple is not affected by high frequency interference.
The temperature is, indeed, close to the boiling point of water.
My installation only boils water.  :(
p.s.
Well, and by what mechanism does a water molecule disintegrate in you?
Ionic or free radical ? If by ionic, then what discharges charged ions?
kolbacict
https://overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg557368/#msg557368
Is it possible to break the connection by swinging the oscillations parametrically ?
Similar to how it is done in the link above (according to Milkovich.)
h20power
For me the water molecules break down into it's component elements by way of "Ionization" where the atoms undergo ionization and release their electrons as then there is nothing left to hold the molecules together since the atoms form an ionic bond.
Everything must be as perfect as one can make them as the water bath can't have any grounds or any way for it to bleed it's charge while being charged up. If so more than likely it will reach an equilibrium state and never charge up enough to be able to ionize the atoms that make up the water molecules. My cell is so isolated that even now after weeks of none use it holds a charge on the plates of the capacitor. From what I see a lot of folks doing is trying to make up new rules of building things without trying to understand why the secondary side of the VIC circuit must remain an isolated circuit at all times. This is to include the WFC as after all it is a part of the VIC circuit. I have no idea why people choose to not follow what Meyer did and instead try and do it their own way when their understanding of this technology is at the beginner level. To me it just doesn't make any logical sense for people to stray away from what Don Gable shared with everyone until they have a firm understanding of just what is going on with this technology. Maybe it's pride or a desire for fame or they just what to say they did it their way, but what ever it is practically all I have seen working on this technology is stricken by whatever mental sickness this is.
I built things as close to perfect as I could and studied this technology thoroughly and afterwards once I had gained an understanding of this technology did I start to make changes to it. I guess no is willing to put in the time it takes to undergo that task as I did. The scientific method is just a tool and we all should be making use of it not just me as after all the tool is free for all to make use of.
Right now I am in fund raising mode so that I can be able to afford the things I need to get this technology into the marketplace.
As for what going on in that other thread I won't even pay it any attention as I keep things strictly towards doing what my experiments showed me was true while I was investigating this technology learning it's secrets the old fashion way. This technology is complex and trying to add in another technology will make it even more so so why even bother?
Shalom,
Edward
