Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
4Tesla
@plengo
I built the two transistor oscillator circuit.. It works.
4Tesla
Bruce_TPU
Hey guys,
Thank all of you for the traveling wishes.
I am back at home and at the bench.  First experiment was a bust, with the mini motor.  It ran fine  while the 9volt was connected, but died the moment the leads were released.  So that is a no go, no way.  Just not enough current available.  I had tied it into the same location as my LED.
Right now I am testing a LC setup with the two control wires.  I want to try this set up again, using only one turn of each wire, a bit larger diameter wire, for less resistance.   ;)
I also picked up my mini solar cell today.  That will be a fun future test also!
I will keep you posted if (when) something interesting develops.
Holiday Cheers,
Bruce
Motorcoach1
@ btentzer >Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  http://babelfish.yahoo.com/translate_url?tt=url&trurl=http%3A%2F%2Fdigilander.libero.it%2Faltraenergia%2Fmarinov.html&lp=it_en&.intl=us&fr=b1ie7Ã,   you may find this arcive interesting , It seems to have been lost but someone posted it on the net I would make a copy before it's gone again. The date is interesting too !!
4Tesla
Quote from: 4Tesla on December 11, 2007, 12:21:53 AM
@wattsup
Not yet.. I'm going to call tomorrow and see what the status is.. I never bought anything from this company before.. I found them through Google.. I hope they are real.
4Tesla
Didn't call in time.. they close at 4pm EST and I'm in the PST zone, so I have to call before 1pm..  I saw on their site that it can take up to 15 days before they ship.. plus shipping time.. up to three weeks to get the parts.. only two weeks for me so far..  If I remember, I'll try to call before 1pm tomorrow.
4Tesla
4Tesla
I don't have my toroids yet.. but have been playing with LED circuits and just verified that running LEDs in series takes less current to run.. each time I add another LED it takes 2-4 less mA to run the circuit.. I have reduced the current by 10mA by just adding more LEDs in series.. it doesn't seem to effect the brightness of the LEDs.  I found that running the LEDs in parallel doesn't reduce the circuit current.  I would have thought since you are lighting more LEDs that the circuit current would go up and not down.  Does anyone know why it goes down?  Something to do with the diode voltage drop?
Thanks,
4Tesla
