"Self Running 900 Watt Fuelless Electrical Generator" Is this new?
Started by bourne, December 16, 2007, 11:07:06 AM
innovation_station
 ;D 8) ;)
look familiar .........
hummmmm    how could it work .......  lol
ist
one
EM
I have  thought for a long time that resonance is one of the major  keys  for unlocking  OU
I remember  Tesla  once said  if it wasn't for  resonance there would be nothing interesting about  electrical engineering
Your plan looks good to me ........ what about   adding a cap   to the red coil and making it  resonant  too ?
gary
one
EM
I  have been thinking  about this  motor
It  does look like it  can't possably  work  .
It  is not actually  driven  by anything .
It is  started  by  giving it a spin
If  you  spin  it fast enough to ring  it  into resonance  the  resonance  should take over.
The key  will be if the interaction  of the rotor  magnets and the  resonance are constructive or  destructive.
Other   attempts  at  OU motors  try to  capture  flyback  ..... WIth  this  motor if  the  interaction   is constructive  as I suspect it  is    ...,. ALL the  flyback  will be  captured  automaticly
If   the interaction   is found to be partly  constructive    some  pieces of  iron  might  be needed  to shape the  magnetic fields
gary
EMdevices
QuoteIt is  started  by  giving it a spin..
hi gary,  are you describing another motor concept than what's in the video?   In the video he drives the generator with the motor, and I intend to do the same thing at first.   I just left off the motor from the drawings since I'm assuming its obvious.    But what you say is interesting.  I certainly hope to improve upon it and make it self running without a "motor" per say, but it will have the motor function incorporated into it, like the Adam/Bedini motors etc..    Right now the chalenge for me is to engineer the magnetic circuit so I get as high an inductance as possible, so I won't need a box full of capacitors.   I'm trying to push the envelope towards High RPM,  lots of poles, closed magnetic circuit with very small air gap.  I have a set of lightweight neos and that's what I want to use, it will probably be disc shaped.
It would be so awesome if at some RPM the thing started running itself, so I can disconect the motor, sort of like the rusian experimental testbed for the SEARL device.
EM
Groundloop
@EMdevices,
Here's what I did deduce from the picture.
Not sure if this setup will work or not.  :D
Groundloop.
