Steven Mark´s associate Jack Durban comes forward with more info !
Started by zapnic, March 17, 2008, 04:28:58 AM
wattsup
@Jdo300
Here are some questions.
Under a heading of "Cutting the TPU"
1) Were you there when SM cut the TPU.
2) Do you know what happened to that particular TPU and the cut parts.
3) If you were there, can you describe what you saw.
4) Do you remember any preparation discussions on any strategy SM wanted to use in order to decide were to do the cut on the TPU. Example - Location of least impact on the operation, location of least internal windings.
5) Before cutting the TPU he said it took him 6 months to build the unit. Do you agree and what in the unit could possibly take so long to build. Example 50,000 feet of wire, etc.
Under any other headings;
1) Have you ever had discussions about wire type such as Litz wire, lamp wire, bailing wire.
2) Did any of the TPUs make any peculiar sounds, clicking, ticking, snaps, etc.
3) Regarding the Open TPU (demo video in a garage) were he put on two magnets, we know he pushed a switch on the device and we also know there were batteries in one of the units legs and the unit was getting hot to the touch. Do you now anything else about this unit? Such as ring material(s), the circuit was visible - did you see it up close, etc.
General Questions;
1) As an inventor and holder of many patents yourself, did you not find it rather puzzling that SM would be able to build his first TPU, and afterwards have sooooooooo much trouble building a second one. This type of situation would be more consistent with someone having a TPU fall in their lap from who knows were, and afterwards trying to replicate it without taking it apart to not break the only working model. What are you thoughts about this.
2) What are your thoughts on why this technology is not already available on the market. Do you believe this technology was shelved or has the TPU remained in an unreliable state. Please elaborate.
Regarding the Large TPU (LPTU)
1) What are values of the two black capacitors and the two yellow capacitors.
2) There is a white connector. Do you know how many wires were on each side.
3) The two center toroid coils were mounted on their own original brackets making these either off the shelf toroids or taken off some other equipment. Do you  know anything about them.
4) Have you ever made a rough wiring diagram of the LPTU as per the wires that are visible.
5) The TPU was mounted on some pretty thick wooden base. Why so thick. We can calculate that according to such thickness SM could have had up to 200 x 9 volt batteries hidden under the base of the TPU. Any comments on this.
6) Do you know anything about the internal core material of the LTPU.
7) SM said the LPTU was "made with bailing wire". Do you know what he meant by this.
8) The only place there could be a circuit is in that small black box under the two toroids. SM talked about 2-3 frequencies, pure audio signals, moving a magnet over 1000 wires. In 1996, it would be impossible to harbor mosfets, drivers, heat sinks plus the energy required to drive these inside that black box. Do you know anything about what is inside that black box.
Any of these questions would be good to answer.
Thanks in advance.
bolt
Quote from: acerzw on March 18, 2008, 03:26:40 PM
@jdo300
It might be worth asking him if he is aware of how SM solved the problem of it working only one way up, the answer might give a useful indication into its method of operation. Also it might be useful to know if he was aware of any major construction/operational differences in the different size models.
A
Logically remove the biasing which created one way up operation to start with.  The early models has the small toroidal right on top. This must have provided up bias. In later models you notice the small toroidal sat lower and lower till eventually it was inside the tpu in the small units. This comes at a cost of efficiency though because when you understand about the construction of the emulator you will notice you lose the 3D target by doing this. I dunno about you but its the least of anyones worries.:)
Earl
Quote from: wattsup on March 18, 2008, 04:20:13 PM
@Jdo300
[snip]
WattsUp,
the two center toroid cores are standard, everyday common-mode line chokes.
Normally they are used between the wall outlet and the electronic equipment.
All switching power supplies need them.
They let the 50 -60 Hertz line voltage through, but block higher frequencies.
Would be perfect to let the DC from the collector pass through, while blocking high-frequency noise.
Earl
bolt
Errm of course thats not true! Are you sure you really mean 1996 and not 1896? :) I was making hi power RF amps using mosfets back around 1990. However i suspect that when the thing is running right hardly any power was required. From Bedinni to Joe Newman stuff they all tell you that all you need is volts not amps to create a catalyst. Thus it would be very easy to use one of the miniature 12 volt round batteries which is about 1/2 size  AAA used in remote alarm fobs. 3 shift registers, one clock, 3 fets should get change out of 50 mA. Once the unit is running don't use any battery power.
