AETHER VORTEX TPU
Started by FatBird, March 25, 2008, 07:21:53 AM
FatBird
SPARKS posted a Aether Votex Unit in another thread.  I did a search & found a site where they claimed working units:
http://dallastexas.net/PinkyAndTheBrain/archive/
The following is a SAMPLE EXCERPT of 1 of the posts from that URL SITE above.  Does anyone know anything about this?
Here is a summary of the specs of my very crude duplication of Clifford Hazelton's free energy device.  Two aluminum plate 6 inches in diameter and 4.25 inches apart.  Alu plates are horizontal, flat.  The plates are fed with a high voltage coil which puts out about 25 to 30  KV at one watt of power. That is very low power. It takes 15 minutes to charge a 25 KV capacitor bank that can be hooked to the supply.
For this experiment the capacitor bank was not connected. The HV supply has, as part of its construction, a HV fullwave diode bridge recitifier. The output from the bridge is connected directly to the Alu plates using jumper cords from Radio Shak. The HV supply was connected directly from the output of the bridge off the supply to the two plates. Luck would have it that I connected the right terminals to the top and bottom disk.
At this time I don't know whether top was + or minus.  The torroid coil. I made it by taking a piece of 1/2 inch tubing, putting a dowell into it to make it rigid, and wrapped (very sloppy) a bunch of turns. I figure if it would work, sloppy was ok. I pulled the dowell out.  Stuck a 2 inch piece of dowell into one end of the tube/coil and connected the other end into the other end of the coil. Voilla, a crude torroidal coil. Probably 75 turns of #28 wire on coil.  The finished coil is similar to one of those SLINKY coil toys.
I put the coil into the aluminum disk sandwich on the bottom as that seemed to be where the wide end of the vortex would be from Cliff's discussion and the rolling ball experiment. Then connected a 1000 ohm resistor to each lead of the torroid coil using more jumpers. Hooked a voltmeter across the resistor with two more jumper to measure voltage. Actually tried two different loads, 1000 ohms and 165 ohms. Getting about 35 to 55 volts on the 1000 ohm and 70-109 volts on the 165 ohm.
FatBird
Floyd Sweet just had a rotating Aether Vortex spinning between the 2 flat magnets.  Edwin Gray had it spinning inside his special tube.  Hubbard had it spinning inside his circumference of pulsing electromagnets.  The TESTATICA Device has it spinning inside the two large cans.  SM had it spinning inside sequentially pulsing control coils arranged in a Toroid.  These are just different ways of accomplishing the same thing.
That is why SM's early TPUs wouldn't work upside down.  When he flipped them over, the spin came to a gradual stop.  That also coincides with what SM called the "INERTIA EFFECT".  In essence, SM proved that Aether will only spin in 1 direction in the northern hemisphere.  When flipped over, no Aether spin = no output.  Neither SM nor Floyd Sweet really knew the relevance of the spinning Aether Vortex.  Remember in one video where SM said "Now you tell me why it won't work upside down."  Yes, SM is a Very Brilliant Man, but at the time he really didn't understand that the TPU output power was coming from the Aether Vortex.
FatBird
Hmmmmmmmmm, It sure looks like IT WORKS to me, according to this post.
http://dallastexas.net/PinkyAndTheBrain/archive/00000173.htm
Here is the Main Site in case it was missed:
FatBird
The nice thing about this invention is that there are NO frequencies & NO Control Coils to worry about like there are with SM's TPU.
