Free energy generating coil.
Started by synchro1, September 10, 2012, 10:32:48 AM
synchro1
@Gadgetmall,
        Try placing a diametric tube magnet in the air core of a bifilar spool of thin gauge magnet wire connected Tesla Hi-Voltage. Connect a capacitor and fast switching diode in series between the leads, and measure the capacitor voltage. There's no way this won't work!
@Doug1,
              What's the magnet coil do on the wheel chair, charge the battery?  Here's a better look at the Magnet Pump. This Tesla bifilar was professionally shop wound  1 to 1. Wired this way, looped back to source, the experiment was designed to demonstrate pooof of overunity. Too bad it fried!
http://www.youtube.com/watch?v=PgcZMojb_-I&list=UUGj-eKaG5_tMGNr_yuLePkA&index=19&feature=plcp
Here's a hyperlink to Tesla's patent 413353:
http://www.magnetosynergie.com/Downloads/Brevets-N-Tesla/BT026.pdf
Hope
Quote from: e2matrix on September 16, 2012, 10:37:44 PM
Thanks gadgetmall for the diagram.  I think that is correct for the Cook configuration although a bifilar, tri or quadfilar from what I've found seems to always connect a pair of wires from opposite ends together.  BTW that diagram with the dual Avramenko setup you posted like below is one I decided to try today.  It slowly built up to over 2.5 volts in about 20 minutes once I switched to some glass diodes.  I started with Schottky's but they were barely getting 1 millivolt.  I think the glass diodes were germanium but not 1n34's.
I also finally graduated from Joule Thief school  - LOL  - I dont' think I ever had built one that worked but got one to work easily today.  I think my attempt last night was with a bad transistor.  I was trying to get one also built per Groundloops extra low current version to try running that off the dual Avramenko power (thus no battery at all) but GL's setup didn't work at all for me.  The regular JT would light off the dual AV plug just for a blink but that was all.  I didn't really have an Antenna setup either - just a wire hanging out a 2nd story window.  It did seem to help a bit when I ran it through that big coil of intercom wire though.
Not clear to me here, is that schematic the working one you are using eman?
Also, Stephan had a BOXMOTOR video showing results as the first video after the OU banner video.   I could not get the "more info" button to work.   Please link me to that topic or tell me how to research it?  Thx  Hope  (Richard)   I am going back to all the items Tesla had to work with..,....somewhere they hid the conduction ....my bet is they made all the wire insulated for more than just insulation for our safety.
Doug1
Gadget
  "What's the magnet coil do on the wheel chair, charge the battery?"
   It's a breaking device, works backwards. Alaways on unless you energize it in the other direction to release it. When it is on or off all the way it will stay in that possition without additional input. If the elec magnet is partially energized it will provide light drag or feathered breaking without feeding it continously. It's a fairly nice piece of work.
synchro1
@Doug1,
           Thanks for the wheel chair brake explaination.
           Here's a video by Nickz where he lights an LED off an exciter with no battery attached. He theorizes the power comes from the "stray capacitive link between the household A.C. and the Exciter".
http://www.youtube.com/watch?v=Xur_VChGdzE&feature=channel&list=UL
e2matrix
Quote from: Hope on October 13, 2012, 01:53:35 AM
Yes,  that is essentially what I was trying.  I was not seeing enough power from that setup to dig into it further but sometime I'd like to try it with a large outside antenna or large metal plate like Tesla has shown in some of his devices.
