0 Members and 144 Guests are viewing this topic.
Hoppy
[quote author=NickZ link=topic=12736.msg471581#msg471581 date=1453217516
   Hoppy:  Ok, understand that.  What I'm referring to, is what T-1000 mentioned, concerning seeing a reduction of the input power drawn from the source (PS), at resonance, (amplification, gain, etz.).
Nick,
Tell me how you would determine that, in order to be cetain that it did in fact represent an amplification of load power ?
NickZ
    Hoppy:
   By disconnecting the PS, or battery. As SR showed, which I think would do, to determine that.
  In any case I'm not too concerned about that idea, at the moment.
   More like,
   finding the reason that my Kacher doesn't create a proper sync. That's what's on my mind.
  The induction circuit seams to be fairly easy to control, but having the Kacher actually doing something towards
the "amplification effect", is something else.  I see the effect on my scope, but not at the bulbs.
    I still have some doubts that any of the videos, like Geo's, or Urfa's are actually showing an amplification of load power, over the input source provided.
  Time will tell.  Waiting patiently for that self runner... to light the way.
GeoFusion
Hi Guyz :)
Yes, What I really want is for us to put our heads together,
we are so close to know how the device works, yet for what I managed up till now.We need to do further testings on this.
   Jeg, :)
yes, I will see where I could get  analog meter Volts and amps both Dc and Ac for the further tests.
  Hoppy,
Yes measuring equipments to continue to see differences, will make sure to get them asap.
Tomtech29,
Hi there x), Yes amp analog meter is needed for measurements, I drew a schematic for you too see. down.
  Nick,
24V is fed to  Kacher input. As well PushPull. you will see in Diagram Edited on how I have everything hooked up.
Look at the Mediator connections and where effect takes place. follow the lines carefully, and see where I have it striped as example if tested.
Below here I have what is currently hooked up now. Today I will Continue with Experimentation.
Output is HV DC!!   it can be Done connecting Load to the AC lines
but DC line has better output with the proper Bipolar capacitors.
Sometimes I Have no idea what I'm expecting or what connections I might make, but It's Doing Something Exciting! :)
https://www.youtube.com/watch?v=7ELg1TclytM
            Cheerz~
Hoppy
Quote from: NickZ on January 19, 2016, 11:42:17 AM
    Hoppy:
   By disconnecting the PS. As SR showed, which I think would do, to determine that.
Or not?
That would completely shut down the device! T100 says that it needs to be established that there is an amplification of power before the device is looped.
NickZ
  Yes, good point.  Let's not get hung on it though.
   He also suggested that we should try to get the feed-back circuit going, with no load, to see if there is any self running of the device, first.  Then add the load, to see if it will run it, and to what extent. If I remember well.
   Geo, Thanks,  I'll study the diagram and get on it.
