0 Members and 143 Guests are viewing this topic.
apecore
Quote from: itsu on November 20, 2016, 02:33:12 PM
Hmmmm,   allthough the upper picture in post #15922 reads: "drain signal.jpg", it in fact is the gate signal as i understand it, and verpies mentioned in post #15925 that
it is "not accpetable", confirmed by Apecore.
I know i had my share of gate feedback problems too.
Itsu
Itsu,
It is indeed the gate signal.
Unfortenatly wrong filename mentioned,...  can't modify,...  as i tried to open the post.
conico
Ok , then you must solve the gate problem and then you will find the big problem , the drain signals coming from the yoke.
apecore
Quote from: conico on November 20, 2016, 03:09:38 PM
What i also have tried is to wind the primairy pushpull (2 x 12T) bifilar)\
It was also posted some time ago.
It gives less spikes but also lower output
conico
Is what i'm doing now,  a double primary and lossless clamp, it would seem that is the only solution for clean signals on drains.
I will use 10-18% duty cycle so, lower power for push-pull.
Bat1Robin2
If you clean up those signals to good you will loose the effect because it is the signal from the tesla pulse that causes the effect of shutting down early the yoke drive fet in mid push. After all it is a field effect transistor and it is being effected by a field. That comes from beyond the gate drive. If you filter or shield it too much then the effect will be lost. Just my opinion and observations from scope shots. Has anyone been pulsing the tesla multiple times during a yoke pulse? As another version of the ruslan device shows?
