Doug1
 I will show this is a one trick pony that changes how you see everything.
Doug1
 The single magnet is made of a number of turns around a core. The field is around the wire which is transferred to the core. The center of the field inside the coil is stronger then on the outside.Why? I strongly suggest you learn how to do what a child does best, asking why.
  It is contained against itself. Why? because it has two motions against a frame of reference. The spin around the wire and the direction the current is traveling from one end of the core to the other. How do you know? Go flush your toilet and you tell me what you observe.
   The magnet is made of turns over a core and the number of turns gives the current more times to circle the core effecting more domains ,but the longer the wire the more it resists the current and the lower the current becomes that can pass through the turns of wire.Otherwise looked at as consuming less current. Agree or not?
Doug1
Conversely a stronger magnet requires a stronger current travels around the core more times which is like saying it needs to be both hot and cold at the same time.
  So lets dissect it.
A coil with a core of a 1000 turns supplied with 100 volts at 10 amps. Produces a field of strength equal to A.
The total of A is equal to the current going round the coil on the core. Lets dissect it some more. How is the 100volts distributed through the coil on the core where it converts the random domains into a direction which makes the magnet?
  100 volts divided into 1000 turns and the magic number is? .1 volts per turn.
agree or not?
bajac
Quote from: Doug1 on November 29, 2014, 12:38:31 PM
I am not sure I follow you. But you are right, I never thought of comparing an electromagnet with my toilet. I will pay a much closer attention to my toilet the next time I flush it.  :o
Are you referring to a type of vector curl operation?
Doug1
Yes but that is not the important part. It will eventually come together.
