0 Members and 37 Guests are viewing this topic.
ignacio
Felices fiestas y muy prospero año nuevo.
Merry Christmas and very Happy New Year.
darediamond
When Lenz is canceled or Negated in any Electro-magnetic device and or Machine, Endless Wattage can then bé easily drawn from the Air you and I do inhale and exhale.
Lenz law is the Major Road Block to Overunity.
So the winding style of the Primaries is the key to canceling lenz effect in both Figuera and Ramaswani Device.
To make the device perform even better, buy soft Iron Powder, Resin and accelerator and make a Mould to make your own Hourglasslike Core. This type of Core can withstand Extremly high FREQUENCY which is need to better generate at the Secondary High Output Wattage and the Needed Back E.M.F needed to loop the system via the primaries and not sencodary and thus keep the device cool as the collapsing magnetic field in the primaries draw from Ahir Cold Electricity or Radiant Energy or Ambient Energy.
Note: you must connect High Voltage AC Caaps to the leads of the Primaries to absorb Spikes and. To further collect back E.M.F, connect a Full Wave Diode Bridge which is made with Fast Switching High Voltage Diodes and direct that Power to an High Voltage High Micro Farad Capacitor Bank and from there to a Multifillar Wire Wound Lenzless Transformer like the Thanes Heins Trasfomer.
Note that apart from cancelling Lenz with the Clockwise and Counterclowise windings in the Primaries, you MUST use Multifillar Wire (which must also lies side by side and layers of windings separated with suitable Di-electric or insulator like Paper or Plastic tape or mylar) to make your Primaries.
Also, it is best to Insulate each layers of the Secondary coils too to turn it into Capacitor as well.
marathonman
I am curious as to whom or what patent your are basing your info on? i have every patent from Figueras and Buforn printed and sitting right next to me as i speak that i have read at least 40 to 50 times each and not one remotely resemble what you just described.
all i can say is good luck.
darediamond
I base it on what have been generally discovered and achieved over Lenz effect which Fuguera also discovered that made him to successfully build the Fueguera Motionless Generator.
Fuguera used Pulsing DC which is Switch on and off by the ready-made dc  motor-powered mechanical switch.
Whenever you pulse any type of electromagnet, you will always generate Radiant-Energy Mixed Back E.M.F as free Energy. But the amount of that energy your E.Mag can absorb depends on How Well you Wind your Coil to bé a C A P A C I T O R and THE RATE AT WHICH YOU SWITCH the electromagnet because the External Energy or Radiant or Ambient Energy is ever switching. So to capture that FREE ENERGY, you must Pulse your Coil which acts as harvester. This is the secret.
When you pulse any Electromagnet, it turns into a Socket which allows the Air base endless Wattage to Plug into it.
The Clockwise and Counterclockwise winding cancel Lenz or drag. And that would pave way for a Massive Radiant Energy Harvesting.
All Motionless Overunity generator requires Magnetic Core. But  not the case with Motion overunity electric power generators. The coils in the later are most times coreless and that makes them suitable for Extremly high frequency Pulsing.
Overunity is all about using say 10W to Generate 1000W or more. So there is need to find a way to make your coils use very little Amperage to generate High Amperage.
Remember Amps can not bé easily multiplied like Voltage!!!
And excessive Magnetic field can bé generated at High Voltage.
Base on that benefit we can then easily lower input amperage to miliamps and increase Input Voltage to Kilovolt generate the amount of needed Magnetic Strength.
So inview of the forgoing using thin gauge coated copper wire to make a Multifillar-Wound Electromagnet which will bé pulsed is the best. As it will bé able to bear High Voltage and consume very low Amperage.
When your swithing frequency is High, you Magnet consume very Low Amperage the more!!
Another benefit in switching or Pulsing your Primary is that the incoming Ambient Power will keep it cool!!
I recomended Moulded Core because of the Needed High Frequency which your Primary needs to absorb a Large amount of  Air-base Free Power or Electricity.
When you successfully build either Fuguera or Ramaswani Device, instead of Looping the Power Set out of  the Power coming from the secondary, with your Radiant Energy collection Circuit (which will consit of an HV Fast Switching Diodes, HV DC Capacitor Bank and an HV step-down transformer) integrated into the System, you will then simply loop it from the FREE excess energy being Absorbed and delivered as Back.E.M.F by the Primary still.
If anyone do not know how to use Mosfet to Switch the Primaries you can simply buy one low power high torque 12V/24V adjustable DC Motor, make a copper commutator or buy ready-made one, buy 2 pieces 8mm or 10mm bore flange or pillow bearing and buy Carbon Brush to make your Mechanical Switcth the Primaries. It is easy.
ttp://www.aliexpress.com/wholesale?catId=0&initiative_id=AS_20151226043027&SearchText=10000V+2A+diode
http://www.aliexpress.com/item/Miniature-generator-JS-3420-motor-24V-DC-motor-speed-control-high-speed-high-torque-motor/1915368050.html
http://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20151226045217&SearchText=copper+commutator
http://www.aliexpress.com/item/5pcs-Carbon-Brush-Assembly-for-2kw-Honda-Chinese-Gasoline-Generator-5-5-6-5HP-Free-Shipping/32324764844.html?spm=2114.01020208.3.54.uQQOxR&ws_ab_test=searchweb201556_7,searchweb201644_3_79_78_77_82_80_62_81,searchweb201560_3
Quote from: marathonman on December 26, 2015, 02:06:14 AM
marathonman
Quote; "I base it on what have been generally discovered and achieved over Lenz effect which Fuguera also discovered that made him to successfully build the Fueguera Motionless Generator.
Completely conjecture statements based on other people not your own experiments and what Figueras actually attained in his device in which you have no idea.
Quote; "When you pulse any Electromagnet, it turns into a Socket which allows the Air base endless Wattage to Plug into it."
Our entire Universe is electric and is where the power is coming from. Figueras device is not a static electro device. it has Nothing to do with air ever. it will work in space as it pulls directly from the field within it.
Quote; "Fuguera used Pulsing DC which is Switch on and off by the ready-made dc  motor-powered mechanical switch.
Figueras device is Not switched on and off at any time. it is a make before break type setup to avoid voltage spikes which would kill the intended purpose of building up a magnetic fields and maintaining that said fields in the core with harmonious and continuous swinging of that said fields.
but the multifiller info is good as i have attained amazing results from multifiller primary coils. so much so it jumped across the room when pulsed with 100 volts DC. luckily my door helped stop the torpedo. so take Doug's warning as to completely secure your coils or those things between the legs could get amputated.
my torpedo has 3.2 inch long primaries with aprox 654 turns quad filler @ 2 T each. the funny thing is i could not get proper ohms and B field until i took my two inch secondary coil and multiplied it by the golden ratio of 1.618 thus gives ruffly 3.2 inches for my primary. then everything fell into place, so weird.
good luck.
Happy Figuering
