Bashar's Spacecraft Engine
Started by teratologist, November 20, 2013, 04:21:16 PM
Hope
This device just might have the ability to receive different wave lengths of a great variety of signals.  It could very well be possible to use this as an antenna for radio waves just to tweet its responsiveness.  Not that in the end you use it as such.  But if indeed it makes a great radio wave antenna,  what other wavelengths will it concentrate?
If it does work well as a radio wave antenna its compact form may very well be a market edge you could engage to fund your development costs.
This app may help you with development, it is a magnetic field detector.
Max Magnetic Field Detector - Android Apps on Google Play
WTF
I just put 61.9 amps through it and nothing, no effects, not even slightly, the only thing that happen is the rod became warm, so this is where i give up.
Hope
Please post your disk mask overlay artwork,  I just may give it a go WTF.
Thank you for all your efforts,  tremendous work done by you.
WTF
I have uploaded the template in Photoshop format and the full size JPEG, if you can't download from this server, let me know and I upload it to another.
Remember that the size of this is 300mm so you need to keep the same dimensions, otherwise if you resize, the Fibonacci proportions will be incorrect.
I wish you good luck with this, but I can't see how this can work as I have done exactly what's in Bashar's description, but it would be good if somehow you made this work.
I probably got more chance in winning the lottery and I don't even do it. ;D
http://rapidgator.net/file/c101d920ad417ee7d9a1e570cd38008c/Fibonacci.rar.html
Jack Noskills
Quote from: WTF on April 08, 2014, 05:24:03 AM
But Bashar did say each wire should be a separate wire.
I'm thinking that putting an electric current through the device could make a magnetic field as when you put a current through a coil it makes a magnetic field, and when you put a magnet near a coil it makes electric, so they are really the same thing.
With separate wire I understand that wire should have insulation. Now all wires connect each other at cross over points and electrically it is not a spiral anymore. Think about Teslas homopolar generator, it had spirals rotating in a magnetic field and potential was gained in each wire. Output was then taken from the center axis and from the outer edge of the disk.
Maybe if you just twist the wires a bit at cross over points so that they don't touch ? Would be easier to test than building a new spiral mesh using magnet wire.
