How to make multiple Kicks
Started by Neo-X, November 23, 2013, 10:31:20 PM
Neo-X
Quote from: totoalas on November 25, 2013, 03:57:27 AM
Hv + pulse + spark    does this satisfy urge ccircuit ??? ??   neo x
That how i did it
I dont know either if that was the right thing to do but keep on experimenting. If you dont get any power in the collector coils try a different approach.
totoalas
Quote from: Neo-X on November 26, 2013, 09:40:28 AM
Its in the core  kick  amplification   got it???  still have no time to replicate my work
totoalas
Neo-X
@Bruce_TPU
I like more your definition of kick. But i dont aggree in one part that kick has only voltage and no current  If theres only voltage and no current, theres no power based on this simple equation Power = Voltage x Current. I think there is atleast small current in the kick to supply power to the load.
forest
Of course use capacitor to condense kicks and a coil to multiply and then keep all running steady.... not an easy task
Bruce_TPU
Quote from: Neo-X on November 26, 2013, 10:19:07 AM
@Bruce_TPU
Not if you learn to "temporarily disable the effects of the flux" and to allow the electrons to float free from the wire.  And if you then know how to accelerate those electrons close to the speed of light.  Then you have a mini particle accelerator.  And all made from "known" physics.
Electrons moving at the speed of light, would they have an associated magnetic field?  That is the question you have to ask.  Why do these "slow" electrons moving along a wire with no current have a slight magnetic field associated with them when first switched on then off?
Marco took High voltage, coming out of a tip of metal and it moves a compass.  You have to ask, "why?" and "how can I use that?"
How can current velocity be increased?  You must also ask that question.
Steven said that "speed" is everything!  Take a bullet and throw it at a car and it bounces off of the door.  Add velocity to that same bullet and now you have kinetic energy.  And it will pierce through the door.  Steven said that.  It is true.   ;)
Cheers,
Bruce
