Jerry Bayles Chiral Effect Homopolar "A" Vector Alternator, and Syncho Coil.
Started by synchro1, March 13, 2014, 10:51:46 AM
synchro1
The "Electrogavity Waves" projected by the Chiral Disks, pass right through a Faraday cage; Therefore, they would pass right through an induction coil! Hence, there's no way any Lenz Drag can appear in a coil of copper windings. On top of that, the Homopolar fields are stationary! All the output has to generate from the oscillation of "Satellite receiver" magnets. This is all "Free Energy". Naturally, there's Lenz Drag in the magnet core output coil, but so what, everything else is all gravy!
Let me re-emphasize that Jerry Bayles discovered the gravity wave propagation of spinning Chiral Homopolar Disks in resonance, and their oscillatory effect on satellite receiver magnets. I believe this to be a major breakthrough discovery, placing Jerry Bayles in the inventor hall of fame with the all time greats.
synchro1
Jerry Bayles stated he generated output from his spinning chiral homopolar disk EG waves with a coaxial capacitor inside a coil core. Let's take a quick look at that: The top shows a schematic for a formula to calculate the electric field of a coaxial capacitor in Gauss.
The bottom drawing shows the two polarized cylinders of the coaxial capacitor. The point is, this capacitor when charged, is basically the equivalent of an artificial magnet.
This may constitute an improvement over the PM core" Synchro Coil" because the LC tank becomes integral in the magnetic coaxial capacitor core at the correct resonant value. Test comparisons would be needed to find out!
synchro1
Here are three quotes I found to be interesting while researching Scalar waves:
"This means that a pair of magnets that are rthymicly opposing/attracting each other are sending out scalar ripples through space that will slightly perturb the scalar bubble/void between a second pair magnets nearby. The net effect is that the attraction and/or repulsion between the second pair of magnets exhibits a change in strength, even though the magnets and fields themselves are motionless".
"Scalar energy is created when any 2 common electromagnetic waves (usually called the wave and its anti-wave) with the exact same properties come together from two opposite (exactly 180o out of phase in terms of time) converging vectors".
"Scalar energy is found in the magnetic field oscillations produced by the earth, called the Schumann resonance. The Schumann resonance is thought to be created by the magnetic field of the earth and is related mathematically to our planets size, density, rotation, and other factors".
synchro1
A window coil placed around Bayles's spinning balance magnets would generate output with no Lenz drag on the chiral rotor disks. The EG waves would have no effect on the copper coil, only the satellite spinners would be effected by Lenz drag from the window output coil.
I own two large 4" neo disks and a score of 1" neo tubes. I have a watt meter that plugs into a wall outlet, a laser tach and a Lux meter. I plan to spin the twin chiral neo disks with an electric drill at resonant RPM, and draw output from a  magnet core LC "Synchro Coil". I plan to run a DC bulb off the "Synchro Coil" capacitor. I believe the watt meter will not change it's input measure when the "Synchro Coil" DC light bulb is turned on and off. I can measure watts out with the lux meter. I then plan to increase the number of magnet core output coils and I believe that there will be no change in input watts when the additional bulbs are turned on and off. I plan to upload a series of videos to demonstrate this EG wave overunity effect.
synchro1
The diametrically polarized spinner projects a transverse electromagnetic wave along with a a series of longitudinal electro-gravity waves. This would be represented graphically both by a series of concentric circles and a set of spokes radiating out, one over the other. The transverse waves generate Lenz drag in the copper induction coil, while the longituudinal waves are received by the magnet core of the "Synchro Coil", and create the pulsating flutter observed by Conradelectro on the self accelerating reed switch thread. The coil induction creates interference for the "A" vector neutral zone scalar wave potential output at resonance. This interference is no longer present in the Chiral Disks, because they only project a longitudinal EG wave. This would be represented simply by dashed radiating spokes, but no concentric circles. The absence of the transverse waves in the homopolar disks solves all the interference problems the radial spinner created. I have high hopes for a series of very successful tests with the spinning chirals.
