Jerry Bayles Chiral Effect Homopolar "A" Vector Alternator, and Syncho Coil.
Started by synchro1, March 13, 2014, 10:51:46 AM
synchro1
@Tinselkoala,
I believe it would be of vast significance if someone could determine if  balance magnets oscillating at resonance from spinning chiral disks, as demonstrated by Jerry Bayles,  would continue to oscillate inside a Faraday cage. I hope you agree and find time to work this experiment into your schedule. Have a look at this video.
http://www.electrogravity.com/BMRT/BalMagResTests_6.mov
synchro1
@Tinselkoala,
Here's the preface from Jerry's video. He maintains a standing wave is projected from the disks:
                              Chiral Energy Resonance In A Split Energy Magnetic Field.
"It will be demonstrated that there is an energy difference between the left and right sides of a pair of disk magnets that becomes evident when the disk magnets are at key rotation rates. The difference between the left and right frequencies yield the key electrogravitational velocity that is proposed in my online presentation of Electrogravitation as A Unified Field Theory. This is a simple test that reveals hidden complex attributes of the magnetic field that prove that the magnetic field is the key to the gravitational field as well as free energy and force field propulsion. Let us begin the journey now".
Scaler energy is standing waves:
"Scalar energy is created when any 2 common electromagnetic waves (usually called the wave and its anti-wave) with the exact same properties come together from two opposite (exactly 180o out of phase in terms of time) converging vectors".
Jerry is rotating two balanced satellite magnets on an vertical axle 360 degrees at high speed with a prime mover rotor speed of 7.83 hrz, or 470 RPM. These rotating magnets are potentially powerful output rotors. The awesome fact is, this motor motion would be Lenz free and free energy, if actually driven by EG waves, don't you agree?
Any kind of magnetic back drag, if any found,  from the Satellite magnets on the rotor disks could be cancelled by Mu metal shielding which Scalar waves would be able to penetrate!
synchro1
Apparently no response from Tinselkoala, perhaps because any positive results would expose him as total bullshit.
conradelektro
Quote from: synchro1 on March 13, 2014, 09:51:48 PM
Conradelectro got a stack of radial polarized neo tube magnets to flutter on the Self accelerating Reed switch thread this past December.
I wonder if while positioning the stack carefully towards the diametric rotor, if a balance point was reached where both magnets appeared to have equal strength to one another, and a Chiral effect caused an oscillation from the quantum plane along the lines theorized about by Jerry Bayles.
A bit harder to hold the coil core magnets in equilibrium to a spinning rotor, then to attach two disks to a fixed axle!
Sorry, the "fluttering of polarized neo tube magnets" turned out to be a very normal thing which happens whenever one puts any magnet near any spinning magnet.
Please, synchro1, keep my name or nick name out of everything you write or say.
Synchro1 one has the annoying habit of misinterpreting many things he reads in forums or elsewhere on the internet. He may well do that, but it bothers me whenever he tries to draw a connection to me. I never saw any effect he described and I never endorsed any of his wild theories.
I once made the grave error to engage in a forum discusssion with synchro1, which I regret ever since.
Greetings, Conrad
synchro1
@Conradelecktro,
You're just another complete fraud, like Milehigh who started out on this thread maintaining that Jerry Bayles's Chiral Disks were merely diametrically magnetized. You received Electro-gravitational waves in that stack of neo's, and you choose to trivialize the effect to play kiss ass to that know it all freak you call the "Overunity Educator". You don't know what you're talking about. I'm the one who's interpreting the effect as reception of longitudinal waves. You're a big dummy.
You scolded me as a complete clown for maintaining the 7.83 hrz RPM projected Scalar waves that were reinforced by Shumman cavity Scalar wave resonance in the atmosphere. You come out to be that thick a head sausage compared to Jerry Bayles!
Take a look at the  superlative "Hero Badge" awarded to me by Conradelektro:
