COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
Meta
Quote from: web000x on May 01, 2016, 09:34:02 PM
I've come to believe in the significance of sacred geometries for the basis of engineering more useful technologies but I have a feeling that the SERPS process can be achieved using standard transformers and generators.  Sacred geometry seems to be more useful in orgone energy devices.
Your theory is vague.  I need direct engineering ideas.  Like utilizing non linear permeability curves in transformer material that facilitates a rapidly changing inductance function that produces the result of negative resistance.  This I can chew on.
Dave
You might enjoy chewing on Metglass which is the transformer material Bearden selected as the frame of his MEG.
Meta
Dave
Ive never seen sacred geometry used in any orgone box, blanket, belt or cloud buster rods.
I ordered a orgone belt, a long time ago, and it does try to perfect everything it comes close to. It heals. It fights with DOR or EM radiation.
The belt is simply a inner layer of organic material (wool) then a outer layer of inorganic material (steel wool) then alternately repeat three times ending with the inorganic on the outside....this attracts orgone which has many other names as follows:
Aether has 13 other names:
1 collisionless shock waves
2 plasma;
3 soliton* waves;
4 radiant matter; a product of radiation.
5 od (Scandinavia);
6 prana (East India);
7 etheric energy; a product of radiation.
8 orgone;
9 The 4th state of matter (plasma?);
10 neutrino sea;
11 graviton;
12 Tachyon Field;
13 Feinberg field.
*Soliton [MATH]: A solution of a nonlinear differential equation that propagates with a characteristic constant shape.     Thomas L. Navarro
So, if you're familiar with any of these other names, you may be able to move forward.
Meta
Meta
Dave,
I noticed that solitons are listed as one type of non-linear behavior........
Types of nonlinear behaviors
Classical chaos – the behavior of a system cannot be predicted.
Multistability – alternating between two or more exclusive states.
Aperiodic oscillations – functions that do not repeat values after some period (otherwise known as chaotic oscillations or chaos).
Amplitude death – any oscillations present in the system cease due to some kind of interaction with other system or feedback by the same system.
Solitons – self-reinforcing solitary waves
Khwartz
Quote from: web000x on April 15, 2016, 05:35:58 PM
This is my generalized schematic:  http://i1082.photobucket.com/albums/j365/web000x/image_zpsq8bci5qx.jpeg
S3 and S4 open when their respective side of the transformer winding goes positive.  When S3 is open, S4 is closed and visa versa.  This allows for the caps to only see one polarity.  You can see in Jim's old SERPS videos that he used polarized caps.  Trying to use unpolarized caps and running the circuit according to my original diagram produces a waveform that is nothing like what paul and jim showed at the conference.  The caps being seated on the center leg of the xfmr and only charging to one polarity is much closer to their waveform.
Dave
Dear Dave, sorry for the very late reply :/
With your explanations and new schematic, I Perfectly Understand how now each half of the secondary of your transformer goes one way only alternatively; Very Thanks :) I updated my reading of the thread and will study your circuit after.
Regards, Didier.
