TPU successfull replicaction? COP=10 1kw torroid
Started by Neo-X, May 17, 2014, 02:35:52 AM
Bruce_TPU
Quote from: MileHigh on December 09, 2014, 10:43:15 AM
Bruce:
Do as you wish. I am not making any claims but I have built things and I have experimented.  Right now you are the talking head.  You are like a late-night infomercial.  Nothing you do is real until the time arrives where you actually show something that works.  That is what it is all about.  It would appear that you have been at this for several years but you don't have anything to show for it.
Stick your head in the sand for now.  But when you come up for air,the outstanding question from everyone is "Does it work and can you do a credible demonstration proving that it works?"
Eventually you are going to answer that question Bruce.
Hahaha!  I'm counting on it!    ;D 8)
ballbag
OK guys.  Instead of fighting, has anyone actually tried the configuration in the original PDF from this thread?
Would be interested to see results.
I would love to give it a try, but don't have a spectrum analyser.  I only have one signal generator.  I guess two are essential, but the spectrum analyser you could probably do without as you could just tune it carefully with the sig gens and watch the output?
I wish you would get the last laugh because it would "save the world."  But unfortunately you are not going to get the last laugh.
If I can ask you one thing, it would be to stop the impish little teasers and the silly quizzes.  If you have something to say about what you are doing, then just say it.
You are just playing with a "funky nonsensical transformer" Bruce.  Transformers are as dead as a proverbial doornail.  They can't magically output more power than you put into them because of some "secret sauce" or because of a fantasy belief in "magnetic waves from the Earth."  Have you noticed what happened with the QEG?  It's a shame that it's apparently going to take you something like eight years to figure all of this out for yourself but if that's what you enjoy doing then just keep at it.
Quote from: ballbag on December 09, 2014, 10:59:39 AM
The pdf shows a toroidal transformer with a crippled core.  They state "The results from the prototype indicate that the two 5-watt inputs from the signal generators give an output power of anything up to one kilowatt.  As the inputs are ten  watts between them, the device has a Coefficient of Performance of anything up to 100 and so could be made to power itself very easily indeed, by providing voltage-stabilised, isolated power inputs for the two signal generators driving the device. "
Do you really think that you can connect two signal generators up to a toroidal transformer and then drive a 1000 watt load with the output winding?  This is one in an endless string of claims where people build a replication and then nothing special happens.  Why people make silly pdfs like this I don't know.
Bruce_TPU
Quote from: MileHigh on December 09, 2014, 11:01:47 AM
As always you make the mother of assumptions!  Ha!  But hey if you wish to continue your endless dribble for another 8 years, then hey...
And why would I tell YOU anything?  Hmm....okay I wouldn't!
