Luftbetriebenes Auto
Started by Hans, September 03, 2006, 10:22:08 AM
Kator01
Pese,
ja er ist sehr kreativ. Ich poste mal hier kurz seine Antwort :
Mike
Thanks, I'll see if I can find the message and correct that link.   I think a windmill powered compressor would be usefull and not just for aireating the local pond. (they do sell them for this purpose on the net- just google pond aireators)  There is a lot you can use compressed air for.
  It might not be as efficient as a big windmill alternator (we don't get enough wind for one of them around here) but I figure I can use the small 12v compressors like what you use to pump up a car tire and hook them directly to the blades.
  3-5 foot diameter blades should be more than big enough to run one and if a swivel connector is put on the air line in the center of the pole where it comes down it would be pretty much a low maintenace deal....Build the mill where the compressor mounts and it's axle just goes through a coupler to the blade axle and when one little compressor wears out just buy another for 5-10 dollars on sale somewhere and stick it right back up there.
   What is realIy good about the idea I think is the fact that you can use more than one windmill, waterwheel, pedal pump, etc.... as a source for air and only have to actually have one airmotor and generator or alternator for the system to work. (I have seen some pretty good air motors on the net lately too)  The motor can run at the most efficient speed for the gen side even if you only get enough air to run a cycle once a day.  Hook a basic chip prossessor up to the  setup with a couple of sensors and electric valves and make the whole thing operate on auto.   There is all kinds of things you could make it do then.
Lee
www.leebell.net
Kator
pese
@Kator
Ja das ist recht interessant. Lee wird noch nicht wissen dass es  ,anstatt Fl?gelr?der , sehr interessante vertikale (stehende Walzen) gibt
1 Meter Durchmesser 2 Meter hoch die entschieden bessere Wirkungsgrade schon bei wenig Winddruck bringen.
(Eines kam aus Finland (andere m?sste ich nachsehen). Die kann man auch dort verwenden wo "?mter"
Fl?gelr?der zur eigenen Stromversorgung (oder Luftdruck) verbieten.
Je nach Bauart des Kompressors kann man hohe Dr?cke (bei kleinerer F?rderleistung) erzielen .
So habe ich ?ber 5 Jahre einen Kompressor (f?r Teile-Auswurf an einer Produktionmaschine) laufen
lassen der mit einem 200Watt K?hlschrankkompressor mit nahezu 12 At? in eine Gasflasche speicherte
(mit Druckschalter)  Innen gibt es nur einen 1 Kolben Kompressor der ca 2cm Durchmesser und 3 cm Weg
hatte (daher de 12 At?).
Wer sowas nachbauen will , bitte daran denken , dass ohne Gas die Motorlager und Kolben keine
Schmierung haben . Also erst normales ?l ansaugen lassen , bis alle ruhig l?uft . (ca 0,5-1 ltr).
Nat?rlich muss f?r ein Hybrid Benzin/Lufdruck Auto  ein Kompressor her der ?ber 12 At? erzeugt.
Kompressionsdruck  und Luft-Motor m?ssen nicht so stark sein , wie bei "autonomen Luftdruckautos"
da in der Hybridversion , ja nur eine Teilleistung zur Unterst?tzung eines "schwachen" Benzinmotors
gebraucht wird , wenn Spitzenbelastungen (Beschleunigung und Berg) kurzeitig ben?tigt wird.
Beachte dass Aufladung bei Bremsen und Talfahrt "Freie Energien" sind die,als Luftdruck  zugeladen
werden , statt diese Energien in Bremsen in Hitze umzusetzen !
PeseWenn Lee oder Ihr die Windwalzen nicht kennt , suche ich die Links raus ...
Kator01
Hallo Pese,
danke, ja, ich weiss, dass es diese Walzen gibt, aber ein Link w?re sehr hilfreich, ist aber nicht so eilig, denn ich bin eher konzentriert auf die Wasserturbine, die im Forum von http://www.unifiedtheory.org.uk/ beschrieben und wohl in den n?chsten Wochen den ersten Testlauf absolviert. Wenn diese Turbine funktioniert, geht es hier um 10 bis 18 KW - Generatoren.
Kator
pese
Ja die Wasserturbine habe ich gesehen . Ich glaube das die noch einen gr?sseren Effekt h?tte , wenn die
Arbme nicht "gerade" aus dem Zentrum austreten sondern Wirbel- (Schnecken-)f?rmig.
Die Sogwirkung nach aussen w?rde dadurch erh?hen !
(Siehe bei Schauberger Heimkraftwerk)
Im ?brigen haben ALLE Ger?te bei Schauberger, Mazenauer und Clemt "so" -in dieser Art- funktioniert , dass heisst die sind dadurch zum SELBSTL?UFER geworden.
Einen besseren Wirkungsgrad kann man sich ja wohl nicht w?nschen . D.h. mann kommt zum Bereich FE Maschine.
Das es dies bei Clem gegeben hat ( mit ?L ) und ein Antrieb (f. KfZ) gearbeitet hat , steht ausser Frage , dass
die US  (Auto und ?l-)Industrie dies ablehnte steht noch mehr ausser Frage. Bilder zum System und gutes Photo
zum "Motor" finden Sie bei mir . Bessere Beschreibung bei www.evert.de  (engl und deutsch).
Gruss Pese
pese
http://www.borderlands.de/net_pdf/NET0306S18-21.pdf
kator , schau mal
allgemein angenehmer artike zum FE bereich
pese
