Overunity is it possible?
Started by lltfdaniel1, October 08, 2017, 01:41:49 PM
lltfdaniel1
I think some one wants me out of the physics room.
Anyways I see a circuit to tap the earth's electric static power using my own earth circuit ideas.
It now runs with constant rpm power torque thanks to the unbalanced electron spin of the earth, so tapping the unbalanced spin and there you go.
The particle accelerator antenna does its magic to capture ever more energy.
It has to run externally to work like the heat pumps method of externally capturing energy.
You say you don't get much power well there is a solution the partical accelerator antenna.
If you apply this to physics it fully works in an external manner I mean the heat pump has this one solved.
If you did this with gravity it will fully work as well since energy physics apply to all of the different energy's.
I was thinking out side of the bubble.
If you say this does not work well just use the earth's unbalanced electron spin to do work so that it fully works.
So yea just use the earth's unbalanced force it is ready to go.
This can be worked out easy it is using classic em laws and laws of physics so you definitely will get alot of power using a particle accelerator antenna.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
You seem to think this is perpetual motion?
Don't believe in a device that is apparantly self running perpetually?
Believe [size=78%] me with classic em and laws of physics it would make complete sense and agree that it most certainly does work like this and the critical bit is the extraction process and the heat pump has solved it which gives you a cop of 3 externally so it does extract while bypassing lenz law and the like.[/size] whilst being proven technology i rest my case.
If you did the extraction process with a gravity motor the vibrations suck in energy via extraction and it will be a magic perptual gravity wheel when it is not it is using the external extraction process proven in a heat pump and it is clear if you fed this cop 3 energy to feed it self it will get hotter and hotter to no end therectly with no limit, and the potential of this energy if you know it in your own way certainly will give you a cop above 1 and self run magicly via extraction and have power left over for a load.
However the heat pump the way i envisioned it doesn't work like that so with the earth yes you can which is why i cannot stress enough about the unbalanced electron spins of the earth and you already think this is perpetual well no and in anycase it does communicate with the vacuum and draws energy from the vacuum with this process as well which i know.
But with the heat pump externally extracting energy and externally feeding it energy then there you have a self runner via extraction of energy and will work with classic em and laws of physics same with the earth.
If you cannot get a heat pump to self run then 100% i am confident that you use the earths already done spins if you don't know how to get it in an electric circuit and in any case we all know the earth has power and not some balanced lenz law canceling effect if it was like this the earth wouldn't function what so ever i might add because you think it has a balanced flux field, and a balanced flux field doesnt give you torque or power.
So where does the magic perpetual magic happen well the earths unbalanced momentum spins is where it is at where it will accelerate until it is at a constant rpm with power torque and there you go, and for some reason you seem to think they never taught you about this momentum actually it does have it covered and will work.
The momentum of the force of where it gets hotter to no end is where extracted excess of energy is for a load.
It seems you want to believe the very thing behind all of it which caused the universe to exist was done via conversion a solely conversion that is so it is pixie dust.
Since you cannot create nor destory, we no longer exist maybe some wasteful force caused the universe to exist you know a big bang bang.
Absolutely NOTHING goes faster than the speed of light so infinity = light speed, infinity never goes faster than the speed of light.
If you ever master what created the universe, you sir have found the holy grail of free energy and in any case it is obvious that infinity is instantaneous speed, if i were to try an get a basic understanding of how to measure infinity, i would look at the quantum spin that is of this going off to infinity to being with and work out an equation like measuring flux density and the like but with the quantum spin and work it out from there.
I would love to know if science knows what zero point looks like in a picture.
Yep this off to infinity is apart of the process to create energy, i already know zero point it behind all of it.
This off to infinity prove that there is indeed energy in the vacuum and this energy is the creation of power but modern science disprove of this, this energy is what causes it to go off to infinity.
lltfdaniel1
Lets devise a circuit using off to infinity then it will perpetually self run.
I wanted what the electric spins of momentum look like when it goes off to infinity
Tom beradon has mentally communicated to me and thyis is his website and he has been threatened over what he knows he is the real deal. http://www.cheniere.org/ regarding energy existing in the vaccum any case that energy in vaccum are those sub atomic particles and the like in co junction with other atoms
whent those atom do there magic that is a process of creating energy!
If you think u can get power from vaccum then i am sad to say modern science treats it that u cannot extract energy from vaccum because they believe energy cannot be created.
When these sub atomic do there magic for power it is actually creating energy
lltfdaniel1
Somebody did just that he created matter whilst knowing what 'creates power' and is very hard to explain why this happens.
Anyways regarding em force and laws of current physics, you need to be at a fast threshold for it to work, regarding the earth circuit where you power it with extracted energy leaving you with excess power and same with a gravity device using this method.
As for the earth energy extraction circuit both opposing sides must be cancelled out to externally extract energy just like the heat pump and to have it run like a self powered solar panel so it has excess energy to power a load, it is clear your going to have to hit a threshold for this to work and will work.
The momentum of the force which none of you for some reason don't buy will cause it to self run with torque excess to power it self as well as a load at same time, this is fully possible even with your knowledge of electric circuits, and the momentum comes from the earth because there is a momentum present in the earth for you to use.
I don't know how many times i have repeated my self.
Even with the bashing you may as well bash the heat pump.
The extracted energy has to cross over in the circuit.
With conventional circuit design you can indeed achieve a self running earth circuit with power to spare.
I can see accelerating ions which is where it will self run with excess power regarding earth circuit, so it powers the extraction process with power to spare with arrows so that ultimately is proven, the dream is trying to achieve this effect and fails so the device doesn't work but the earth is ready to go with a never ending no limit as to how much you can extract, like the heat pump but this is a different configuration but yea where it gets hotter and hotter to no end there is a bit where it causes this force to give excess power.
This bit in the force where it gives excess energy is the threshold.
There are arrows clearly explaining this effect i am on about and should be clear that it defiantly will give you a self powered device with excess energy as in energy extraction powering the process to extract energy and then with excess power for a load that is what the arrows of momentum means.
It will  self run at a constant rpm with power/torque as have said tons of times.
And isn't breaking the laws what so ever.
The arrows follow the unbalanced electromagnetic spin where it does work/power/torque/unbalanced momentum as have said and shown in a picture with arrows i drew.
This excess energy is what I call power torque you know to power a load as well as the extraction process so it is self sustaining.
So excess energy is the accelerator arrows.
an arrow went off to full acceleration and another arrow showing excess energy all in the same line like a sentence. because it is past the threhold to get excess energy.
This as have said isn't perpetual motion it is a self powered solar panel i cannot stress this enough!
It coerolates with 92% effiency in a motor but this is going at 100 percent and can see that because past 92% per cent so it is now 100 per cent is the excess energy threshold.
what i am trying to say is the law about 92 per cent in a motor this force can bypass that and give you 100 per cent efficiency this above 92 per cent is excess energy territory
so when you are at the threshold it will be like a plane breaking the sound barrier and dunno how to solve that but with the understanding i can see there already widely known how to solve it.
Heart of this is using the acceleration arrows with a particle accelerator antenna.
so same apply with the earth circuit breaking the threshold of 92% law translated below 92 you do not get excess energy but above it you will get excess energy. all to do with the speeds, same with a apparantly self powering gravity motor it needs fast speed to operate and will look like perpetual motion but isnt.
But in this i already know there is a perpetual force which is causing outrage with this device and is where the earth has it s own cold electric as have said again if you remember my previous post and is why you didnt buy this at first.
With the perpetual force you will be able to control the extraction speed/motor rpm instead of going off to no end of speed and burn out. It looks like an unbalanced scalar wave regarding the perpetual force.
Regarding that the earth will automatically give you constant rpm but to manipulate the force of this is the perpetual motion force present in this earth circuit so yea this is causing outrage.
it will self accelerate with the particle accelerator antenna so it speeds up using extracted energy from the atmosphere/ions so it goes faster to power the antenna it self so it amplifiys in that regard so it sucks ever more ions in  from not having excess energy to actually having excess energy - the threshold.
The very thing that propels this into speed going faster and faster is the accelerator it self it doesn't need to be in to accelerate as in no excess energy or excess energy what i mean is the accelerator the process it isnt affected what so ever by the extraction process that is it will just keep on giving an accelerator effect which is what it is.
the accelerator it tied in with a perpetual force as have said and communicates with the vaccum/zpe  from the vacuum/zpe this way and is powered by the vaccum/zpe sustained by the vaccum/zpe
lltfdaniel1
Using a normal antenna doesn't cut the mustard which is why they don't use the earth's power.
A particle accelerator antenna does and is self propergated with the accelerator so it will get bigger and bigger until you pass the threshold and into excess energy, unless you want to tap the accelerator atom it self which is present around the earth which is a different technique as compared with my method of using particle accelerator antenna.
If there is a problem i would look at the principles of the heat pump to fully achieve my goal of extracting power from earth.
Theoretically yes in physic this force give you excess power, only way is how hah.
Like friction is there is friction it will still work because of a process overcoming that problem same with my earth circuit idea ways of overcoming the problems which solutions do exist.
overcoming the bottleneck of the threshold well if the force can do it fine without problems then a circuit will as well.
Either way it will be a lot of static electric because the wave of the antenna will get longer and  longer to no end and reach the ionosphere of the earth where there is a ton of power which is what i achieve with the particle accelerator antenna.
Good news there are people who know how to over come the bottleneck :P .
The thing responseible which is the accelerator looks like a swirl a highly charged particle.
This swirl gets the impossible effect from the vaccum Zpe and is getting it from the vaƧcum when the swirl turns it gets that effect.
When it turns it vibrates the vaccum zpe and this is the core power of it, it is like slamming the vacuum Zpe and yea where the magic happens.
The conjunction of the atom with Zpe is that there is an unbalanced momutum occuring and is excited and is exactly like sub atomic but different energy it resonates with tat energy. Unbalanced in size is what mean like a small vortex and a much bigger one and at an angle of momentum.
Within this s vibration is the key between accelerator and Zpe vaccum energy.
Because you can use the vibration for many things.
The vibration is ocilator between Zpe and the accelerator and how it interacts with each other and I call this the control panel to control the rpm speed and if not use the earth's own rpm regarding my earth circuit where the excess energy is.
I can see a rod taking advantage of the accelerator using physics by capturing the atom and have it run off extracted energy along with propulsion  and taken care of the bottleneck of the threshold.
some silicate compound about the rod captureing this energy.
And some vacuum tube valve as well to attract static/ions and is glowing red hot but fail to see how it would accelerate the process like with my particle accelerator antenna now i see it is using the vacuums way or self attracted ever more energy whereas my idea doesn't have that process and needs an antenna.
Forgive me am brain dead but have a correct consensus.
