0 Members and 1124 Guests are viewing this topic.
Dingus Mungus
Quote from: d3adp00l on July 16, 2007, 11:15:54 PM
If it was (which it is not) 12 time more out then heres the simple test, use the level to produce power to manipulate the pendulum, if it can keep going then it is o/u because it is beating friction, if it can't then its not. This device is the swinging equal to the worm and spur gear thats all.
This is what I'm trying to say... You don't yet understand the prinicples. The lever can only effect the pendulum when its roughly 180 degrees out of phase and its a negitive interaction, but the pendulum always effects the lever positively. I have half a dozen examples of a 2x pendulums swinging longer and harder than a stationary duped pendulum, but it's never going to introduce enough energy to the free wheeling pendulum to close the loop with no additional components. You would be right in saying thats impossible, but based on what I've seen in my experiments there is definitely more going on in this device than people are willing to see. We just need a precision way to tap the pendulum why extracting the output.
Like I said if you're a "nay sayer" get out some wood, pen springs, steel hangers, some paper, and some plyers and test against wind resistance. You'll notice a pendulum with the broad side of a piece of paper on its vertical axis will quickly slow and stop from the air resistance, but when you place the paper on the horizonal lever it has nearly ZERO influence on the pendulums speed or phase. Thats not what physics would refer to as a normal trasfer of potential energy. You're just not looking at the important factors of its operation. Its in no way a ready to develope concept yet, but it absolutely does show its validity IMHO. Please test for yourself and report back if you still don't see it. I'm still trying to think of a better way to harness this gravitional potential feedback in the mean time. If this device was a lot more complicated I think people would give it more benifit of the doubt, but due to its simplistic structure people assume to understand it far too quickly.
~Dingus Mungus
snowblind
Hi
So all the believers out there: this would theoretically work. I just drew this up quickly at work.
Pretty much when the lever pulls up, it pulls a string which pulls back a small hammer, which is pushing against a spring. It passes over a one way clip, which stops it from releasing and is held there. When the pendulum reaches the top and is near the hammer, the lever goes down and it pulls the other string, which pulls the clip and releases the hammer, which pushes the pendulum forward.
Note this is a pretty simple drawing, and would require a lot of tweaking, and pully ratios etc.. but you get the basic idea.
It would need to be atleast 200% efficiant to work like this, as the hammer will get pulled and released when the pendulum is at the other end of its swing aswell, meaning no benifit to the system. if you had a 2 independent pendilum/leaver systems hooked up to the same hammer, but the hammer had a fork shape, and swung the pendulums at opposite ends, it would only need to be 100% efficiant, as it would push each pendulum with each swing.
I hope you can understand this  :-X
Greets from Japan
ltseung888
Explaining the Milkovic Pendulum and Lever system using the Lee-Tseung Lead Out theory.
Many of you are already expecting this.  The Published Lee-Tseung PCT patent information (PCT/IB2005/000138) describes how a Pulse Force on a Pendulum can Lead Out gravitational energy.
Explaining the detailed working of the Milkovic system is now in
http://www.overunity.com/index.php/topic,2794.msg40855.html#msg40855.
There is no magic.  There is indeed Gravitational Energy Lead Out from two complementing systems.  Please comment via the above thread.
@snowblind from Japan,
Good thinking.  Work on it more.  I am confident that you are moving in the right direction.  Energy has been Lead Out.  It is a matter of using it!
Lawrence Tseung
Lee-Tseung Theory Leads Out the secret of the Milkovic system
ltseung888
Improving the Milkovic system.
Please read:
http://www.overunity.com/index.php/topic,2794.msg41011.html#msg41011
Who can help to pass this message to Milkovic?
Regards,
Lawrence Tseung
gyulasun
Quote from: ltseung888 on July 21, 2007, 06:37:21 AM
Please read:
Regards,
Lawrence Tseung
Hello Lawrence,
See Milkovic's contact page info:  http://www.veljkomilkovic.com/KontaktEng.html
Gyula
