0 Members and 27 Guests are viewing this topic.
stivep
Quote from: F6FLT on January 16, 2019, 11:34:42 AM
Schumann resonance does not allow us to send a signal from point A to point B without significant losses. The losses are considerable, question of wavelength far too long for the possible sizes of radiant systems.
In front of you, you do not only have blind believers in fairy tales or uneducated ignoramuses. You have curious, critical and competent minds, with strong objections which you do not respond, or by digressions, and which you confuse with missiles.
QuoteSchumann resonance frequencies are lower than expected for an ideal cavity, i.e., two concentric layers of infinite conductivity filled by a lossless dielectric medium  [Jackson, 1999
https://agupubs.onlinelibrary.wiley.com/doi/10.1029/2002JA009779
https://en.wikipedia.org/wiki/Schumann_resonances
QuoteIn the normal mode descriptions of Schumann resonances, the fundamental mode is a standing wave in the Earth–ionosphere cavity with a wavelength equal to the circumference of the Earth.
That is in my previous post  I said:
QuoteThink about Standing Wave deformation at your higher Schumann Resonance frequency
And you'll get your FE.
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg530166/#msg530166
Quotesome harmonic of the fundamental earth resonant frequency—up to approximately 25 – 35 kHz—is used for the oscillator frequency.
In this frequency range the around-the-world propagation efficiency is in the general area between 93 to 87%
https://teslaresearch.jimdo.com/wardenclyffe-lab-1901-1906/connection-to-earth/proposed-methods-for-terrestrial-resonance/
Please read all of it!!
QuoteAppendix II, "The Zenneck Surface Wave"]
The oscillatory transformer provides the high voltage alternating current needed to periodically charge the transmitter's elevated terminal.
A monochromatic subcarrier signal is then added.
This is in the form of an abrupt lower frequency electrical impulse applied at a rate approaching the fundamental earth resonance frequency.
Higher frequency impulses, above the oscillator frequency are also added at every harmonic of the low frequency subcarrier impulse, be it
the fundamental earth resonance frequency or some lower harmonic of same. [Corum & Corum]
While the following quote refers to the use of an RF alternator in conjunction with a resonance transformer to produce continuous waves,
it appears to be applicable to the excitation of earth resonance modes as well. .
https://patents.google.com/patent/US4751515A/en
QuoteBecause propagation losses are so low at the primary Schumann resonance frequency (below 0.25 dB per Mm according to published data),
signals at that frequency may be transmitted to any point on the earth without significant attenuation.
Wesley
https://www.wired.co.uk/article/230-percent-efficient-leds
Many did read this news but forgot  !
A. "electrical efficiency > 100%" as term for FE devices
B.  " ....   It begins to cool down..."
C.  ".... and applied smaller and smaller voltages. Every time the Voltage was halved,
            the electrical power was reduced by a factor of fourbut the light power only
            dropped by a factor of two.   ...."
Sergh
Quote from: lancaIV on January 17, 2019, 04:21:22 AM
A.  " ...."
B.  " ...."
C.  ".... "
D. "....69 picowatts of light, of course, is a very small amount" 69 picowatts = 0,000 000 000 069 Watt,  very very very small amount energy from ambient heat, not usable.
F6FLT
I had seen this article when it came out, source paper here. It would be revolutionary in principle, since it would be a Maxwell demon.
On the practical side, the energy in question is on the order of tens of pW, so no practical interest without considerable improvements.
But there are worse things. This scientific paper is questionable.  Cooling was not measured but calculated. The paper was refuted, a real measure would have indicated an absence of cooling:
http://large.stanford.edu/courses/2012/ph250/kumar2/
"The authors did not directly observe cooling, mostly because they did not thermally isolate the diode, instead they chose to keep the temperature fixed! They calculate the net cooling. In simple terms, one would not observe cooling in the recombination dominated region."
Quote from: Sergh on January 17, 2019, 04:29:14 AM
"C. THE RATIO FROM POWER FACTOR AND HEAT FACTOR APPLIED "( + Newton* meter Factor)
                  " picowatts "- device as q.e.d. for him and his POWER KW/KVA RATIO description :
               to  mega.
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=2733719&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
