r2fpl
Quote from: Sergh on April 17, 2023, 08:38:40 AM
Allow me to present my vision of this Kapanadze device. This is a conceptual model, it is incomplete, inoperable in this form, etc.
There were suggestions about such a device based on the analysis of small amount information from Internet, the dissemination of which Tariel opposed.
The main completely unusual and incomprehensible detail is a quantum gravitational nanostructured pulsed power cell.  :)
Structurally, it can be like a small battery, similar to CR2032 or another this type. By the way, you can try, discharged elements of similar types should respond to impulse of mechanical pressure.
How it supposedly works:
- a small rechargeable power cell with a very large output current of several tens of amperes, but a very short discharge time of 0.001 - 0.005 seconds. It can probably work both independently or with the supply of the necessary chemicals, liquid or gaseous.
I observed a similar mechanism some time ago in experiments with pulsed electrolysis. If a current pulse is applied to the electrolysis cell, then immediately after the pulse, the cell remains charged up to several volts due to the hydrogen remaining on the electrodes.
You can also make a similar experiment by taking any discharged battery and applying a current pulse to it for several seconds with a voltage several times higher than the nominal, after then immediately measuring the voltage on the element.
But in this experiment is no free energy, it is only an explanation of the mechanism.
It is necessary to find a way to produce hydrogen "on demand", as Tariel did in his "Auto on Water".
The mechanical system of the L2 bobbin and the magnets and cells located inside it can probably work independently for a short time due to mechanical resonance, until desynchronization and weakening of the process occurs due to the consumption of the necessary substance. You can see it in this video with 12:35:
https://youtu.be/2oGHuHy-xEc?t=765
If you spend a lot of time analyzing all the videos and how each device works, you will understand that there is not much in common. I don't want to talk about everything because everyone can see it, but in my opinion it is not possible or rather very unlikely that there is more than one rule! Tariel was definitely cunning and didn't reveal any important information that we would have seen in the film. I will say more, I believe that even one of the films is specially made to mislead people.
In the video from 2004 there is a moment of turning off the device and the sound is unprecedented. It is not a transformer, although it is closest to this sound. I have a sound analysis and there are frequencies around 380-400Hz with modulation around 25-26Hz If sound can tell us anything.
Kapanadze said that it is the switching of the electro-magnet on and off and the impulse gives us what we need. The amount of energy of this impulse is unlimited.
forest
Still nobody translated 2004 video or any other. How do you know Tariel hide details if you don't know what he said ?
a.king21
Quote from: r2fpl on April 17, 2023, 08:23:21 AM
I made various air gaps. I worked with different cores, different shapes as well. Different voltages and different frequencies.
I'll tell you one thing: the current flows or it doesn't. There's no miraculous setting where I'll get a big kick for even a moment to say I found this moment but I don't know how it happened that now it doesn't work. None of these things.
I don't know what Melnichenko sees there, but he certainly didn't show it clearly.
There is even another explanation for what is happening in the barium ferrite core, that is the NMR process. However, it would require a lot of luck to hit this effect, if it is possible to obtain it at all.
Did you use the diodes in the way he tells us?  He says that the diodes are very, very important as they negate losses =  I speculate maybe negates Lenz?
Clearly, pulsed squarewave with variable duty cycles and frequencies is the experiment to be conducted here.
Also, use a magnetometer and see which frequency/duty cycle combination gives the biggest magnetic field.
Also, use very fast diodes. No two diode types are the same.
He also says that you can keep the transformer together by using ordinary cheap insulation tape.
I hope this helps.
a.king21
Quote from: r2fpl on April 17, 2023, 08:28:52 AM
What would the same look like for 5kW lamp ?
I did not assume that he drives the lamps from the transformer.
Clearly, the output comes from the grenade-type coil which has sufficient wire thickness.
However,  there is nothing to stop the big coils from receiving energy from the 100-watt transformer, especially if it is in the MHz range[size=78%].[/size]
We really have to think outside the box and think "simple is best".
To quote Elon Musk: "The best component is no component. There is no cost and no possibility of failure.
What can you remove..."
Remember that resonance requires the wires including tail ends to be precise.
What we see in the Kapanadze videos is unbelievable. People with kitchen knives cutting wires to size in front of the cameras.
It is beyond ridiculous because they knew that they had some knowledge that we don't.
a.king21
Very interesting observation.
When I was asked by my financial backer to design the specifications for the Aquarium 2 device, I made some specific requirements.
1 No switching: I watched the Aquarium 1 video and saw Kapanadze blow a transistor when switching between various devices. This told me immediately that he was no engineer. It would have been simplicity itself to put easily reachable fuses all over the device to protect the circuitry. I would have done - especially in front of potential investors.
2 The device had to output 2 kilowatts for hours and hours. It did; and worked for 4 and a half hours before it was time to finish the demonstration.
I think that this information rules out your interesting hypothesis.
So let's keep analysing the first video because I believe it gives away the most secrets.
ANOTHER THING: I remember asking Tariel what was his first experience with his discovery. He told me he had a 1 kw incandescent lamp and it ran for a full 6 months. He said that he himself was astonished. He has spent all his subsequent life terrified of someone stealing his discovery. He is clearly tortured and takes to drink to ease the psychological pain.
He told me repeatedly that he tries to think of ways of protecting the secret so it can't be copied, but he obviously lacks the electrical engineering knowledge to do it.
  In my opinion, a really talented electrical engineer would understand the principle and be able to hide the discovery inside various circuitry. Let's say it is a transformer that he has doctored: I would make several tiny transformers and put them encased in resin inside resistors, as one way of hiding the invention. Or you can disguise the transformers as chokes for example. No doubt you can think of lots of other ways.
That is why I think the first video holds all the clues we need.
