Energy Generation by moving Mag Field through Static Steel Core & Copper Coils
Started by Ufopolitics, April 07, 2022, 09:40:19 AM
Ufopolitics
Hello,
Some images while I was winding the new tested stator, on previous video...
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
Hello to All,
I will be winding the whole 36 slots Stator next week, it will be on a brand new 20 gauge wire spool that I just bought...
And so, this is the best configuration I could design, conceive, using 100% of all slots, for a total of 18 coils, overlapped.
Each Coil embraces 8 slots, 9 tooth.
The coils windings are separated by the red equator line shown on graphic.
So, All North Coils will be wound CW, and Southern Hemisphere Coils would be wound CCW.
North Hemisphere have Nine (9) Coils
South Hemisphere have Nine (9) Coils
I will be leaving wires out (Termination/End and Start) between coils, in order to be able to measure independently each coil and the best pairing match...it should be at 180º...but we never know.
As depending on each output, I could separate by groups or combinations thereof, like (12/6)- (6/6/6)- (14/4) etc,etc)...in order to search for correct output for the section of Exciter Coils supply (Input)
As also in order to separate output groups for different tests and applications.
I know it will work, because I have already tested four coils in the same config on my previous video...this is just a matter of building more coils...using the whole 360º magnetic field rotating sweep.
Again, I will test and upload a video as soon as done winding, and setting everything, no matter if results are positive or negative.
I am still working on the Toroid Structure...as well.
Ufopolitics
―Leonardo da Vinci
Ufopolitics
GENERATOR STATOR FULL WINDING STARTED...
I already started winding Stator with 20 gauge wire, according to previous shown diagram...slots only allow me 70-75 turns.
I already test Coil 1 yesterday, very successful test!!
Doing Coil#4...14 more to go...
Cheers
Ufopolitics
―Leonardo da Vinci
Ufopolitics
Hello to All,
Here I will be uploading three short recent videos, where I will show the point where I am in the testing of the Virtual Field Rotation plus Generation of Energy as a result.
I have finished the full winding of 18 Coils on the previous Stator Core I have shown...however, I have tried already many different configurations as related to the way I connect Coils in between...and observing results.
On these three videos I have the configuration shown on Diagram, about the way I have interconnected all 18 coils...which is different from the way a typical generator have their Stator Coils connected between them.
On this case I have connected alternatively the coils from North Hemisphere to the coils from the South Hemisphere...
Meaning, C1 End is connected to C10 Start, C10 End is connected to C2 Start, C2 End to C11 Start and so on...
This way have given me a better result in acceleration gain of the rotation of the Magnetic Field.
However, the failed part is that it adds more resistance, hence less output amperage...but still, you will see on the videos I have pretty good amperage output...
Stay tuned to watch the videos in the coming posts.
Thanks
Ufopolitics
―Leonardo da Vinci
Ufopolitics
VIDEO DEMONSTRATING VOLTAGE 2X OVERUNITY
Ok, so on this video I show how the Generator Stators Coils are connected, plus a simple test run showing Output Voltage above Input by Two times or 2X...
SIMPLE VOLTAGE OVERUNITY DEMONSTRATION VIDEO
So, I am feeding Field with 10V as I get Output of 20+ Volts in AC, and around 18.5 in DC...No Electrolytic Caps added on this test, which -of course- will increase Output DC Voltage above shown figures.
No load on this video...just checking V In versus V Out
Stay tuned for next video...
Thks
Ufopolitics
―Leonardo da Vinci
