Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
hartiberlin
Hi Ash,
if you let the output load of 3500 Watts run for
more than  15 minutes and the input power is
no more than 800 Watts all the time with his setup you
can be sure that you have overunity.
For better calculation afterwards try to get the weights
of all the single wheels and their RPM.
There can not be so much storage in these relatively small
flywheels..
Also they do not rotate so fast, so after a few minutes of time
all their stored energy has be used up and if after 15 minutes
the device can still outputs 3500 Watts  with only 800 Watts of
input we really have "free power".
Looking forward to your tests and many thanks again
to Chas to make this possible.
Regards, Stefan.
ashtweth_nihilisti
Hi Stefan,
Thanks man, will do , and thanks for reminding me, you know it sort of reminds me of the RV , where, after they create a resonance condition, they clip the peak of the sine waves, like an energy 'swing' and you only tap the 'peaks' and do not destroy the momentum.
This is also how Chas described it to me, after he creates center fugal force his system maintains the balance, and only a 'tiny' bit of input is needed to keep the action going.
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
hartiberlin
Yes, maybe it has to do with "tapping inertia" !
What is interesting is the change of
acceleration of a mass is
described mathematically by a rocking event ( in German language:
"Ruck")
But next then what is the change of a "Ruck" ?
This is never told in university mechanical classes...
Can a "Ruck" or the change of a "Ruck"  tap inertia ?
ashtweth_nihilisti
Stefan Exactly, what happens when you put a child on a 'swing' and she swings very high and you only tap her with little energy to keep the momentum going.
But how do you extract the energy from the swing so the 'inertia' stays the same?
Perhaps Chas has to a degree done this.
In the RV resonance 'swing' the peak sine waves  'tap' is the extracted OU, well thats how Daivd Kou keeps his battery charged he cant explain it by any other conventional means,its  a little more elaborate with half waves and ful waves AC theory etc, but thats the 'gist' of it. Im not sure if Chas has done the inertia process, your 15 mins test will clear that up.
oouthere
Hiya Ash,
Just let Chas know that even if his machine is found not to be over unity, his altruistic attitude is what we all hold in common.  I thought I had o/u several times, but my understanding had to change to accept the out come.
It'll only take one good idea to make the world a new place!
Rich
