Single Wire Tests
Started by duff, October 31, 2007, 03:42:00 AM
Jdo300
Bruce,
I want to duplicate the experiment with the coil that you and Thaelin saw. Could you post a diagram just for that including where the ground lines for the function generators go? If it is just the picture from your first diagram, do the grounds from the two separate sources connect to each other, or is this some kind of one-wire setup? What frequencies did you use, and were they sine waves or square waves? Also, could you post some information about the coil that you were posting (type of wire, rough number of turns, etc). I'll try and duplicate the experiment.
God Bless,
Jason O
Jdo300
Hello Everyone,
I just came across an interesting tidbit of information about phase inversion (which Steven talked about). I think I see why it is important to have two signals running against each other in the same wire! Look at this article about audio amps:
http://www.tubecad.com/june99/page10.html
God Bless,
Jason O
Bruce_TPU
Hello Jason,
Here are the details of my experiment and also the coil http://www.overunity.com/index.php/topic,2300.msg36995.html#msg36995
But, before you wind that coil, I am convinced you will see this on any coil.  So I would strongly suggest using one of your existing coils first, before putting the effort into winding this one.
The key is to make sure that each frequency gen has a different power source, that the signals are identical, no deviation, and that they are slightly out of phase of one another.  60 volts or more would be best, if you are set up for that.
I hope that helps.
Cheers my friend,
Bruce
BEP
Jason,
Any common point between the two sources is slf defeating - ground or otherwise.
The more sure way to see this effect is to have two separate FET drivers circuits, each with its own battery suppy (not power supply) and opto or otherwise isolated inputs. Then you could use a two channel freek genny.
The best way to see the result is not with a scope probe but with a magnetic pickup like a coil or Hall Effect probe - better yet a secondary coil off the tested primary. The phase offset can be zero initially - this will cause the collision in the center of the coil (if all else is perfect). A phase inversion (in classical AC terms) will cause cancellation of the voltage.
Two Pulses (DC) of the same frequency hitting the opposite ends of the coil at the same time should meet in the middle. The potential should not be cancelled - only the magnetic field as the two magnetic fields are inverted polarity to one another.
A phase difference with only two signals will only cause the collision point to move on a solenoid coil. Now do the same on a toroidal coil and you have a cat chasing its tail.
Jdo300
Hi BEP,
Ahhh that makes perfect sense there. Now the only thing I'm wondering is weather it works better with coils a many turns or few turns. When I think about what is happening here, I am tempted to say that it would be a longitudinal wave traveling, and therefore a few loose windings with some spacing would be good, but then again, I'm also thinking about the idea of building up a large magnetic field, (or canceling it all together) which could go either way... What are your thoughts on this?
God Bless,
Jason O
