Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
Bruce_TPU
@ Sanmankl
I forgot to add the diode on the negative side of the 1.5 uf cap.  It is facing the negative.  Weird I know, but it added time.   ;)  I posted some time ago about it and forgot to update it to the circuit.
@ All
I am out of town for a short bit, and then I will be back experimenting.  I have some more experiments to run with my two control wires still.  After that I will tie in a mini 1-3volt motor I found today.  I will glue a magnet on the shaft and attempt to spin that in the center of the toroid while the LED blinks, with no battery hooked up, just used to kick start.  Also, I will be purchasing a small solar cell, and place this above the LED's and then tie that back into the starting position.  It should make for some fun experimenting if nothing else!   ;D
Once I have finished with all of the above, I will unwrap my control wires from the toroid, and wrap two additional toroids in the configuration that Mannix gave.  The only difference I will make is that the wrapping will be bifilar, and I will but some other type of wire around the circumference, underneath.  (You never know, eh?  LOL)
I still say that SM's secret is in the very specific frequencies and their intersection.  IMHO.  There is more than that, but that with tubes, is really the starting place.  But for my non EE self, this is fun, and educational.
Holiday Cheers,
Bruce
4Tesla
Bruce,
Have a safe trip and talk to you when you get back.
4Tesla
wattsup
@btentzer
Have a good trip.
@4tesla
Did you get any word form your parts supplier. I ordered some stuff there also a week ago and still no news. Anyways, they did not touch my credit card yet, so I  guess they will when they ship my order.
sanmankl
@Bruce,
Thanks for the diode update. I haven't got round to duplicate your setup yet but will soon enough. Have a safe trip.
So far, my best times based somewhat on EM's circuit (RC cap changed to 200nF, LED to negative) is 34m 50s.
Seems like there's still a way to get longer run if the torriod size/type-wire size/type gets into proper "harmony"?
My latest is a torriod core of about 40mm size, Fe (black in colour) with AWG#20 wire. I'm in a way lucky. I can walk into one of my regular electronic component shop and pick various size torriods for cheap. Paid something like USD1 for the 40mm Fe ring.
Cheers, cp
4Tesla
@wattsup
Not yet.. I'm going to call tomorrow and see what the status is.. I never bought anything from this company before.. I found them through Google.. I hope they are real.
4Tesla
